Surface Mount LEDs
Has anyone purchased any surface mount LEDs from an electronics supplier in the US.
What did you buy and where did you buy them. I think 603 LEDs are most suitable for model rr use. There are so many different ones, I would like an idea what works best.
I use these. They come in different configurations.
http://www.ulrichmodels.biz/servlet/the-350/Miniature-Surface-Mount-LEDs/Detail
www.ngineering.com has an excellent selection. They are ,8mm x 1 mm (2.8"x3.4" in ho)
They are also very hard to mount. I like to glue them in place, then draw conductive paint to the leads (Commonly available at auto parts stores to fix rear window defroster lines) I then paint over that.
Using a soldering pencil is a quick way to melt a diode given it’s size.
Richmond Controls has surface mount LED’s with small 6 inch wires attached.
A bunch easier that trying to solder your own wires to the LED’s.
Several DCC shops have inventory of these- One that I know about is Litchfield Station.
In addition to the sources already mentioned, surface mount LEds are available in many configurations from More LEDs and SuperBright LEDs.
http://www.moreleds.com
http://www.superbrightleds.com
Soldering SMDs (surface mounted diodes) requires a solder smaller than .032, a digital soldering iron set to 450-500 degrees and plenty of experience. a hobby pencil iron will not get hot enough or have the control to use on SMDs. glueing is the best alternative and there are some adhesives that will accept a circuit.
I buy mine from one of the Asian sellers on ebay. FIFTY of them in warm white, plus free shipping for only $9.99 !!!
I’ve bought from them numerous times and had them within a week. Excellent color rendition and not a bad one in the lot.
Mark.
