Surging P2K GP30
I have a pretty new GP30 that runs terribly. Its speed varies badly when running at very low speeds. I checked the wheels (in gauge, not bent, making good electrical contact) and the axle gears. What would be the likely cause of this? I assume it might have something to do with the worm or the gear that the worm meshes with.
Any comments from experienced P2K owners?
george
Does it make any clicking or occasional clucking noise as it runs? A cracked gear sounds like a flat spot on a wheel tread.
Bob K.
You say new GP30…are you sure it’s new?It could have been on the shelf for years. I just got one and had the same problem plus cracked axles. I thought it was just the axles. That helped but it still surged. If the light flickers then you still have poor contact. I eventually looked at the wheels and they were corroded. This is just surface corrosion. After I cleaned them with my wire brass brush wheel cleaner til they shone it ran great. So check that out and hopefully it will solve your problem.
Balantrae Road has the right idea, particularly if you are running DC. If you are running DCC there may be other issues.
I would refrain from cleaning your wheels with a wire brush. This creates scratches in the wheel, which gives dirt a place to accumulate. Since you’re going to disassemble the trucks to check the axles/gears, I would clean the wheels with a cotton rag and some alcohol.
My P2K U28b has some issues as well. It just shuts down by itself in DCC for a second or two and then comes back. I wont be purchasing P2K ever again.
The axle gears are definitely OK, and the wheels look good. There is no problem with conductivity. After all this thing has a soundtrax DSD - LC in it and as we all know, those decoders are intolerant of connectivity problems. That’s why I’m thinking it is in the gears someplace. I will have to pull the gear towers apart I guess.
And I don’t hear any chicken-like noises coming from it either so I’m thinking that none of the gears are cracked (not just the axle gears).
g
I assume you’re running DCC… one thing I’m always suspicious of with “surging” is that you may have two throttles talking to the loco at the same time… sending conflicting data.
