SW wiring
Have an sw but no instruction sheet. If combination bu gives 19v is that fixed?Is AU19 volt variable? Similar for cu and du but 14 volts?
And u posts linked internally so that only one of them needs a wire to another transformer for coordinating use after polarity match?
A-U is 19 volts variable.
B-U is 19 volts fixed.
C-U is 14 volts fixed.
D-U is 19 volts variable.
Larry
