I have 7 turnouts in tunnels. I was careful laying track, and didn’t have a whole lot of trouble, but in a couple places, there were more problems than I wanted to deal with.
It cost me some serious effort to straighten it all out. Ramp up the throttle to a crawl, run clear around the table, whip on my magnifying glasses and flashlight, bend down to look through a birds nest of risers to get just the right viewing angle on the wheel, realize I missed the exact moment of failure, repeat, repeat, repeat, repeat till I figured out what was going wrong then it was adjust, repeat, adjust, repeat, adjust, repeat…
I haven’t had a derailment in there since I fixed the problems, probably three or four months, not one. You can do that too, if you’re willing to put in the time and effort.
Removable mountains aren’t very tough. Glue down your first two layers of 2" foam, then use bamboo skewers to pin down the rest of the peak. You can glue all the upper layers together too, just don’t glue them to the first two. Carve at will, lift off the upper section and plaster cloth the lower two layers. Drape Saran wrap over the top of the two lowest layers, so that at least an inch hangs over the edge.
Set the top section back in place and run your pllster cloth throughout, allowing it to lap over about half an inch. Short blocks of wood leaned onto streategic areas will help press down the wet plaster cloth and saran wrap, but perfection isn’t necessary. I like to do a medium area and then come back for the second layer of cloth, it gives the first layer time to get a little stiff, but not too stiff for fine adjustments, then the second layer locks it in place.
When it’s all dry, mix some water with lighweight spackling compound to get a cool whip consistency and paint in on with a one inch brush. Back and forth at first, to fill all the cracks, then gradually start working out the brush marks with up and down strokes. Stick to the most nearly vertical fall lines, fo
