switching turnouts automatically??
was wondering if it is possible to switch a turnout automatically. for example getting a locomotive to make a switch to change the tunout position as it travels its route. ( so the locomotive can travel a desired route through turnouts)
If each turnout has an accessory decoder the MRC system does the following: (from the manual)
Grouping of turnouts (or accessories) can be consisted to form a route. The
Prodigy Advance DCC system allows up to 31 routes and up to 8
accessories in each route.
The Prodigy Advance will handle most NMRA compatible accessory
decoders. This type of decoder can operate turnouts (switch tracks) or
toggle accessories, like building lights, on and off from your Cab.
If you want the locomotive to automatically activate a switch as it approaches you need detection.
http://digitrax.com/prd_statdec_bdl168.php
If you just want to throw a series of switches with a single command, you can do that with a Digitrax DS64.
http://digitrax.com/prd_statdec_ds64.php
Because the DS64 can get it’s commands through the track, it will work with any brand DCC system that can issue switch commands.
Other manufacturers probably have similar decoders.
is there any way to group a certain number of turnouts together to form a route with digitrax?? i was informed that you could with an mrc system. wondering if digitrax offers the same thing.
Read the last entry in this forum before yours. It is the answer to the question you just asked.
