T6 project part 2
The atlas RS11 shells have arrived. I realized i have two P2K s-1 here with all the guys and such. Even better, the door arrangement is correct for the T6. Just change out the radiator section. Yippee right. Nope. The atlas RS11 measures 6 foot wide. The S-1 measure 5 foot wide. I looked up dimensions for a T6. And found the only drawings had photobucket plastered on it and were blurry. Useless. So which is right? 6 foot or 5 foot wide hood? Does the atlas S-1 have the same measurement?
shane
I don’t know anything about Alco’s, but I did find this:
http://thedieselshop.us/DataS1S3.HTML
It says the engine hood is 6’10", the cab 10’.
This looks like a pretty handi site.
https://www.thedieselshop.us/
Mike.
Thank you. I didnt find that one. Tells me the P2K is too narrow and tha atlas shell is much closer. Off to find atlas s-1
shane
Hi…
Say, where were you able to find Atlas RS-11 shells? None available on the Atlas site.
Thanks in advance and good luck with your project!
EDIT: Update, I did find some RS- 11 shells on Atlas, but they appear to be the old version with the molded on grabirons. I was looking for the newer ones.
Seems odd, that site lists all the RS models (well, RS-1 to RS-3) as 5’05", I have huge doubts that the S1 is a foot and a half wider. You think it would be easy to find a top down view to compare the hood width to the track gauge…
No, I just now measured my older Atlas S-1, and its hood (not over the radiator louvres), measures about 5’9" or 5’10" in width.
You have to go into the exploded view sheets and find the model you want. Each of the parts is identified with a clickable number that takes you to the part. I find not al lavaliablee parts are listed on the parts pages for some reason.
These are the meazsurements that came off the physical models I have. not prototype drawings. I used a tool for measuring outside circumferences ( i cannt think of the name of it. Looks like a compass with the ends bent inward). I compared the widths to a scale rule and that is what I found the models to be. Most likely factory variation. Between a P2K S-1 and the Atlas RS11 measured at the point the two would be joined.
Wayne, that means the Atlas S-1 will much more closely match thier RS11 in width. A nominal difference if any.
Shane
