I sometimes look at loaded railcars and wonder how some things are unloaded. A few examples are: open-top wood chip cars, and the old, beat-up gondolas full of scrap metal. How are they unloaded?
Woodchip gons: with dumpers–either rotary dumpers or devices that stand the cars on end (if the cars have an end door at the A end, which a lot of them do).
Those old scrap gons: either with an electromagnet or one of those claw-type devices at the end of a backhoe (which can also be used for demolition of buildings, grappling ties, or whatever; I don’t have the technical name for it).
There’s a machine that stands 268,000# railcars on end?[:P] I’ve got to get me one of those-it sounds fun![;)] It sounds like this would be at a paper mill, which, I’m sure would have a lot of big, expensive machines. Granted, the only wood chip cars I’ve seen are on the DM&E, and look pretty beat up and old. I wouldn’t have been to surprised, if you had told me that someone opened the end door, and unloaded them with a bobcat.
There is a place that sells ground covers that receives bark in woodchip gondolas. They have nothing out there that looks like it could be a rotory dumper or lift the car up. I suspect they use tractors to unload the stuff. By the way, all the cars are dump end gondolas.
That is probably mainly due to the treatment by the scrap yards. Have you ever seen that “Dirty Jobs” episode where Mike Rowe works in a scrap yard? Don’t forget all of the stories we have read on here about how they abuse the gondolas.
Cement is shipped in regular covered hoppers and in covered hoppers that use pressure to assist in unloading. If the lading is likely to stick to the car, they probably use a vibrator to loosen it.
I have no clue on the wood chip cars, but I have seen the gons unloaded by the large magnic, and the large claws. I know in mapleton, IL there is a CAT plant. CAT usually uses the magnics, and they sometimes will lift the gons off of there trucks. It is not uncommon to find this situation.
The Chip Plant here at Thornton yard in Vancouver uses front end loaders to unload chip cars, they secure them next to the loading dock, open the door on the A end, drive on and unload them that way.
