Hi
I just needed to stop for a while and chat. I’m in the middle of building my new layout. It’s HO, it’s 15’ x 12’, it’s a double decker, it’s DCC and it’s in my loft. I spent about a year planning and designing and drawing and measuring and reading and re-reading and re-designing and 10 weeks ago started my build. Well, first of all, I had to stregthen the floor. That took a good three weeks. Then I had to recover from hitting my head on the beams supporting the roof. Then I went out, bought the timber, passed it up one length at a time into the loft through the opening where the ladder goes that enables me to get up into the loft. Then I started. Measure, measure, saw, saw, drill, drill, check, re-check, throw away length of wrongly cut wood, measure measure, saw, saw.
All the while, being in the loft, I continuously hit my head on the beams that held up the roof. Not intentionally of course, accidentally. My wife’s belief that I was born accident prone being proven over and over again. I put down the drill before it had stopped spinning and it wrapped the underlay of the intended carpet around itself. Stop for 10 minutes to unwrap underlay. I clamped the wood base together with all my clamps leaving just one to get. I only had a very large and heavy G clamp left to use and had to balance wood, clamp and hold in position. Prayed for one extra hand to no avail. Reached for drill, largest clamp fell, foot in path of trajectory, bruised toe, much swearing, much hopping.
Tools disappear just at the moment you need them. Use a tape measure, put it down. Hold timber, look for clamp. Clamp vanished. Look around cannot find clamp. Put down timber, clamp miraculously appears. Clamp timber, look for tape measure to double check measurement, tape measure vanishes. Look for tape. Clamp falls off. Tape suddenly appears.
Occasionally my wife Hilary will call up after a particularly heavy BANG! or a THU
