As i have seen the factory installed decoder is Loksound with 21 pin socket (not the most common 8 socket) and the speakers are connected to the printed circuit board and not directly to the decoder as usual, and are 8 ohm not the (again usual) 100 ohm.
So my question is
Are the decoders from the market exactly the same with the Factory installed decoder? So they use 8 omm speakers just because are connected through the printed circuit board?
Railroad, BLI/PCM have their own forum at the website. You are welcome to register and then to pose your question on the HO forum. Their moderator is usually very quick to give you info or to orient your question to the right tech folks at BLI. You’ll get help quickly there.
The basic LokSound decoders come with a short cable that has a standard NMRA 8 pin socket/plug interface. The speaker is 100 ohm, and attaches to the decoder module. At lest that is what the after-market US decoders look like. They sound very good…
Jim
They sound very good…except for that very quiet horn. The horn should be the loudest thing on a locomotive. The volume limit is the result of the 100 ohm speaker. Any louder and you would overload it.
David B
