Why is it that locomotive manufacturers (diesel and steam) and structure kit (specifically laser kit) manufacturers use technical terms in their user guides and instructions, yet almost never define those terms or define - or even illustrate - only some? Very few people I’ve ever met are architects, engineers, technicians, designers, home builders and the like to whom technical terminology is a second language.
The user guides for the three different makes of locomotives I own are next to worthless; two of them are esentially for ordering spare parts with purely generic instructions for lubing certain areas of the locos. The third specifies lubing only one part of the loco and leaves the others unmentioned. Sample wording: “Lube the worm gears, idle gears and bearing areas.” I give them credit though for specifying what type of lube to use, but there is no diagram showing where they are or what they look like. Yes, I know what a gear looks like, but how many are there and where are they? Bearing areas? Ditto. Also, “Use light oil on the axles.” That’s good for the axles, but no mention at all is made for lubing whatever other parts lurk inside that loco that also require maintenance.
A couple of laser kit terms (for building a bridge, depot, house, etc. from three different manufacturers I own) that immediately come to mind are “bents” and “roof returns.” I eventually learned what “bents” are, though “roof returns” remain a mystery. That’s just a small sampling, as I’m sure there are more. Again, no
