This may apply to any tender with a LED/board wiring. The tender has no decoder, but only 2 wires that run to the light board. It has no resistors/capacitors on the board. I have a few questions.
When using a multimeter, what setting do I use for a DCC equipped loco DC or AC to measure the voltage? I know that I must set it to the lowest reading initially. I burnt a DCC decoder once trying to read the voltage and I don’t want to repeat it with a DCC/Sound equipped loco.
What are the usual classifications for LED’s…1.2V or 12V?
How can I correctly test/troubleshoot a burnt LED…or does an LED look “burnt out” like a bulb? Thanks for any info.
Thanks for the reply. I checked it at the bulb and got 9.2V, so I assume it to be a 12V LED? I have power all the way up to the bulb. The board is just that, it is a board with no resistors/capacitors and i could just as well bypass it as it reads the same voltage coming out of the loco.
You are confusing bulbs and LED. There are no 12 volt LEDs. There are 1.5 volt and 12 volt bulbs. If it is a LED, the resistor must be in the loco. When there is a 1.5 volt bulb, there will be a resistor. I have hit a LED with 12 volts accidently and the LED Popped. You can not test an LED with an ohm meter. You have to put the meter in series with one lead with the meter in say the 200ma current option. Be carfull or you can burn out the meter or at least pop the protective fuse.
If the headlight is a bulb, you will measure low resistance using the ohm meter.
How about telling us what the brand and type of loco you have? All the DCC steam locos I have are LED headlights but i know there are variations, i.e., bulbs.
This is a lot to consider if you do not understand electronics very well.
Here is a link to DCC for new people. There is a lot of electronics info for you.
http://www.members.optusnet.com.au/nswmn/index.htm
I replaced it with a 3.6V LED from Radio Snack and it works just fine. Thanks.
