I don’t understand why someone as intelligent as Elon Musk would state publicly that an Electric Truck is going to eat the rails freight business for lunch. Such a remarkably stupid claim. An electric truck is still going to expend more energy moving freight vs. rail just by the use of rubber tires. Not to mention that tonnage is still restricted by state laws along with current length of the truck.
Musk has always been about the BIG STATEMENT, no matter if it is fact or fantasy.
Cost of electricity per HP-Hr at the wheel is a fraction of the same for diesel fuel, so that would be an advantage for the electric truck. I’ll leave it up to someone else to do the research and math to quantify that. Also, presuming the electric truck would still have the usual driver.
Power supply would be an issue, though. If batteries, there’s likely to be significant - even prohibitive - economics effects from the resulting tare weight for any long-haul. Alternatively, if a catenary or other in-motion power replenishment system is utilized, someone is going to have to pay the massive capital costs to install it. May as well do that for the railroad first.
- PDN.
It also occurs to me that Tesla recently merged with SolarCity (solar photovoltaic panels and energy storage) and that the average truck trailer has almost 400 square feet of “acreage” on the roof alone for mounting solar panels.
Read this comment on an EV site right after the Tesla truck announcement:
“Some simple (simplistic? I’m not a mechanical/electrical engineer) math: The Model S weighs 4,600 lbs., with 1,200 of those being the battery. Similar power- to-weight ratio for loaded 80,000 semi would require a 21,000 lb. battery pack. A typical diesel-powered tractor weighs 18,000 lbs, with engine and transmission weighing 5,000 lbs. Thus, the shell and battery combination for a Tesla tractor would be 34,000 pounds. (Did Tesla give any specs?).
“The Tesla weight penalty would be 13,000 pounds, versus diesel. Competitively intolerable, when the typical truckload is 40,000 lbs.”
Sounds order-of-magnitude correct to me.
Spot price for #2 fuel oil is currently just under $2/gal - figure something on the order of 15 kwhr/gal equivalent mechanical energy. This works out to an equivalent of $0.13/kwhr. Wholesale prices were quoted instead of pump prices as there will almost certainly be a road use fee of some sort to make up for the lost fuel tax.
Estimates for electricity cost from PV and stored in batteries is around $0.40/kwhr, spot prices for wholesale electricity can run from a few cents per kwhr to over a dollar - charging at 7PM is likely to be extremely expensive. Musk is claiming $0.07/kwhr, but… Charging stations will almost certainly need large stationary batteries to meet demand.
Estimate for battery weight is 12,000 lb based on assumption of 1 MWhr for a 500 mile range. This means ther tractor will weigh more than a diesel rig.
Costs lower than rail assume truck convoying, which I don’t see happening in urban areas without a dedicated roadway - which will be expensive.
Big market I see for electric semi’s would be from Long Beach/San Pedro to the Inland Empire logistics warehouses. One issue is that there won’t be much time to recharge.
If you listened to the entire presentation, the requirement to be more efficient than rail was to have a truck with a driver that would be followed by two or three drone trucks. Never mentioned what the addition of million or so extra trucks daily would do to the already clogged Interstate Highways. Should make I-95, and the other interstates just a stroll in the park at rush hour, and bankrupt most state highway funds.
He stated that the cost of running three or more “platooned” electric trucks would approach the cost of shipping rail. Without knowing the cost of the electric trucks… the cost of building the infratructure nationwide and internationally to support such trucks as well as other costs, I wouldn’t want to speculate as to how accurate or how far off the mark such a statement is. But, from a competitive standpoint railroads would do well to assume the worst i.e. that such trucks will be much more competitive than current diesel trucks, especially on short to medium hauls.
A very significant amount of the ‘clogging’ is explicitly due to the longer following distance and ‘reserve’ for braking required by OTR drivers in general traffic. Minimizing the number of drivers who have to react and respond, especially in stop-and-go or broken traffic, is a very meaningful first step to fixing, not enhancing, traffic problems. Under conditions where substantial traffic in some lanes is at least semi-autonomous, the contribution of intelligent and predictive truck operation will be even more substantial.
Of course the thing we all realize is that the economics of trucks with hybrid transmissions and sustainer engines is far better than idiot proposals to make them ‘all-electric’. In case anyone has not noticed, the case for hybrid locomotives is still waiting better and lighter battery chemistry, even with much of the weight of the battery array constituting ballast rather than an explicit operational ‘drawback’.
I confess that sometimes I have funny ideas about what constitutes ‘trolling’ a community. Musk advocating straight electric transmission as a ‘cure’ for situations largely involving intelligent or autonomous infrastructure … is flirting with some of the lines in the sand involved.
A much better dismal scenario is the counterpart of truck stops for all-electric Class 8 vehicles, but we don’t need to go there yet; just look at the fun involved even at this early date with ‘Supercharger’ and other EV recharge points on the road as the ‘take rate’ for Tesla and other plug-in cars and light vehicles increases…
Electric Battery Transit Buses have not worked out because of the weight and the costs of maintance. However Trolley wire buses have worked for the last 100 years so installing miles of Catanary on our freeway system might work. That being said Dayton Ohios new Nextgen bus that can run on and off had been delayed by Federal Regulaters.
We went from the Wright Brothers’ experiments on the sand dunes of Kitty Hawk to commercial production of the DC3 in only 33 years… just something to keep in mind about the pace of change sometimes. Electric semi autonomous trucks will imho be here sooner than later. The status quo from an environmental and economic perspective is simply untenable… thus big changes coming soon to roads and highways near you.
Stalled at the side of the road in a blizzard
Yes, but… where are our SSTs? Where are our flying cars? Where is commercial V/STOL? Sometimes possible technology is not expedient technology, or can be converted into successfully implemented technology. The straight electric truck (as opposed to the battery-centric EV car) is one place that I expect to see demonstrated … and supplanted by vehicles with onboard charging and emergency-power capability.
I would also make no more long-term bet on investing now in autonomous technology than I would on Nikola Tesla’s broadcast power plans from Wardenclyffe a century ago. Even if the current craze for teradata system fusion pans out (and I suspect it will be tried with deterministic logic first, and harebrained ‘fuzzy logic’ second) it won’t take very many opportunistic lawyers to get any practice of the idea crippled if not shut down. I expect the same thing to affect real-world platooning of fully autonomous vehicles sooner rather than later. Regardless of the actual cause of an accident, you can bet it will become the company’$ re$pon$ibility pretty quickly.
There was no commercial demand for the SST or flying cars… or even c/stol… In contrast there’s huge pent up demand for a cheaper, cleaner, easier to use alternative to the trucking status quo. So much so that some well known brands have already pre ordered the Tesla truck… You can be sure that the traditonal name brands like Peterbilt and International are working full tilt to come up with their own version of the electric tractor trailer… they’re not going to let Tesla walk away with marketshare. They all know now that’s it’s all about being first out of the gate with a production model… the race is on!
Why the big boys are ordering Teslas is simple TAX CREDITS. If your willing to run any alternative fuels like LNG CNG electric drives the DOT will give an OTR company a 60K credit per vechile ordered. Now those trucks are great in captive service say between terminal runs like they are going to get used. However in OTR service they will not be worth it. Why to short of range. Even my single tank tanker fleet can outrange a any alternative fuel truck right now.
Thanks, erikem! Good analysis, as always.
- PDN.
The electric truck is well advanced in development, and the more traditional manufacturers are not only better aware of the appropriate ‘niches’ for all-electric power, but also the infrastructure needed to sustain them. Mercedes, not Tesla, had the first workable ‘ready-for-production’ BEV heavy truck prototype, and Cummins among others is working out the correct version of hybrid-electric technology for North American service. If you look in the truck-technology magazines you will find many examples in testing or prototype stage, and you can be sure there are more in development.
The Europeans have started up a program to research and then presumably implement better charging systems:
At least some of the results would be applicable here, but again the major uses of BEV without at least small sustainer engines would be in urban areas or restricted-route service, where a multiplicity of capable charge points and the electricity-fairy capacity to supply them economically on demand can cost-effectively exist.
Remember the situation in Europe is a bit different in that they consider CO2 a primary pollutant and are willing to leverage alternative and renewable generation to achieve absolute reduction in its emissions. We in the United States are still fumbling with feel-good green credits and often misplaced systems of subsidies for equipment purchases; whether this will lead to practical use
Paul,
You’re welcome!
The $0.40/kwhr was from an on-line magazine article and may be somewhat on the high side if we’re projecting out to 2020. I work out a couple of somewhat lower estimates which shouldn’t be lowballing too much.
Best case, figure a $1.00/watt for installed PV, 2,000 hours per year of sunshine, and 10 years lifetime. With these assumptions, the price of raw PV power would be $0.05/kwhr. Since charging will often be taking place when the sun don’t shine, let’s assume about 6 hours of battery storage minimum, and assume $166/kwhr for the cost of battery and support, along with a 10 year lifetime. With these additional assumptions, storage will kick in another $0.05/kwhr, so we’re looking at $0.10/kwhr, which is more than the $0.07/kwhr that Musk was promising. Note that these costs don’t include maintenance, property taxes, land costs or road use taxes.
One unstated assumption for the previous paragraph was that the charging station would be able to sell all of the electricity generated that day, where a real world station would either need to overbuild on charging and batteries, or make use of commercial power for peak demand/ low generation days. Once all these costs are added in, the $0.40/kwhr doesn’t seem outrageously high.
Very little has been said about how road use fees would be charged to electric semi’s, which makes me wonder if electric semis would make sense. Hybrids semi’s may be another story, as energy from regenerative braking can be put to good use.
As for platooning, I don’t see that as being practical in urban Southern California much after 5AM or before 11PM.
- Erik
Analysts doubt Tesla’s claim that its Semi would be a rail killer
Trains (Online)
[quote user=“By Bill Stephens”]
November 21, 2017
Tesla founder and CEO Elon Musk says his company’s battery-powered big rig, unveiled last week, will be 20 percent cheaper to operate than diesel trucks and represents “economic suicide for rail.”
But reports of rail’s impending death may be exaggerated.
“Is this going to be a game-changer? No, not yet anyway,” says Larry Gross, an intermodal analyst at Gross Transportation Consulting.
Industry analysts say the Tesla Semi does not appear to match th
stack trains cheepest way to ship freight so muskrats trucks wont make a big dent till newer tech comes along if then. merry christmas
