My pleasure! Though I am quite disappointed with the results of the test… I mean come on, it was only a four-axle geep - not exactly heavy, is it? The track should have survived…
Jason,
I’d bet a thousdsand feet of it… that it will withstand a a very pretty HO gauge GMD-1 which I would like to test with…
Thank You Sir!! - For cracking me up, & having fun with you do!!!
Excellence!!!
I believe your testing method was flawed. I spotted the problem right away. You made the mistake of using an older engine that obviously had “pizza cutter” wheels on it. Newer “scale wheels” would not have torn up the track like that. Also I believe if you rerun the test using a Tier 4 compliant engine you also could have better results.
Of course your mileage may vary, good luck in the production of the Bendy Track. I look forward to trying it once it hits the market.
Actually you’re not so far off! If you look closely at the wheel you’ll see it’s developed a flange on the outside as well as the inside. I am regularly at VIA’s maintenance centre and I’ve never seen wheels like that (though with the coming budget cuts I may start seeing them). That geep is properly worn out…
We’re having a lot of fun with this stuff (as if you couldn’t tell!). You haven’t seen our FPA-4 dance number yet… [:D]
