I’ve been inactive in model railroading for about 20 years. I’ve just started resurrecting some N scale equipment that I bought back then (I was modeling in HO but had moved to a smaller house). Among the equipment I have is a TFAS 2 throttle that I built from an article in MR, and all I have is a very fragile, yellowed copy of the schematic. By experimenting, I’ve figured out the throttle and momentum controls, but there is a second potentiometer on the handheld unit, and two trimmer pots on the circuit board and I have no idea what they do or how to adjust them.
With the momentum control set all the way down, the throttle behaves as I would expect it to, but as soon as I add even a little bit of momentum, the engine sits motionless for a few seconds and then takes off at about 50 MPH, even at a throttle setting that just has it barely moving without the momentum. I suspect that at least part of the issue has to do with the lower current draw for an N scale locomotive vs. an HO scale one.
Does anybody have any information about this throttle and how to set it up properly?
Thanks.
Walt
