I went into more depth in the original post, but a quick recap would be, and not necessarily in any order-
found a few wheels to be slightly too wide. I found this after paying close attention to derailments and marking each axle with a marker. Throughout the process of changing trucks around and wheelsets around, when a certain wheelset kept derailing, I started comparing closely to others that weren’t, and found them to be slightly wider. Also found a few (plastic) to be bent and wobbling down the way. Being bent obviously causing wide then narrow conditions with each revolution. These will become MOW and gondola loads.
With the trucks, I’m not sure yet there. Some of the derailing trucks, through trial and error, ended up on different cars and ran fine.?.? One truck was a different design in that it did not contain regualr coil springs, nor what I’ve seen here for leaf springs, but it was so loose and floppy that set is scrapped for now. Some had some apparent flashing problems, and even possibly a weak spring, but until I can clear my work table I am not attempting any repairs there. Simply swapped for rigid plastic.
And on some of my non-sprung cars I found out-of-gauge wheels (wide), and car bodies too low, shimming those with regular card stock from my super glue package.
One turnout, and I don’t remember the make, had an issue with some cars coming from the rail onto the point rail at the fixed, or riveted end, and the flanges either going up and over the point rail, or in-between the point rail, traveling then between the point rail and the stock rail, if that makes sense. Some measurements, and a keen eye, with the knowledge gained here that factory stuff can be out of gauge, found the fixed rail to become slightly narrow at the rivet end. That was fun, as I thought I could give the rail a slight bend and ended up popping it right out of four ties and bending it! Some work rebending, some super glue, and pressure applied with a screw driver tip, w
