thanks for all your thoughts
after hearing everyone. i think i will try without the pledge, polish. item is clean and that should help with adhesion. i will be using model master decal setting solution and microscale’s Micro Flat. i also have a decal solvent solution for complex surfaces.
i don’t think i need the later since, beleive it is the same as the setting solution. anyon clear me up on this??
Try to not click on the button labeled “New post”. Despite the label. it does not actually make a new post in the same thread - it starts a totally new thread, divorced from the thread you are trying to follow up on. The button ought to not have been there. Instead, to follow up on a thread, click on “reply” on one of the posts.
Here is the thread you no doubt was trying to follow up on: http://cs.trains.com/mrr/f/88/t/209532.aspx
Smile,
Stein
As Stein suggested, “Click on Reply to one of the Posts on the given thread”. Your Post will appear at the end of other Posts. If you want to Edit your post to correct a typo, or to add something, you then click on the little pencil at the left bottom of your Post. Make your correction an then scroll down to Post and click on it. Do you know how to Post a photo, or a scanned diagram ? If you don’t, start a new Post, and I will explain. Bob Hahn
