That's enough of a break--where is it?
Lovely array of signals–three lights each on four tracks–when you face east.
All four tracks go under concrete–and a little coal dust–west of the signals.
Follow the signals east about 25 miles and you might find yourself on camera! I did!
Go south on the tracks and you might encounter some new trackage being built.
Take the tracks west and you’ll cross an ancient truss bridge, and go past a spot where 0-8-0s lived through the 1970s.
Small town, big railroading. Not too much else.
Where am I?
(Not in Michigan this time)
So we’re east of Sterling, Illinois. I suppose it could be the C&NW coaling tower at De Kalb, but I can’t recall four tracks going beneath it, only two.
S. Hadid
You’re right–it’s not DeKalb. But you may have just given it away to dozens of folks on this forum!
Wow! One I knew off of the first post! Yay me! I’ll hold off a bit and let someone else get it.
Nelson, IL. (UP, Steam at Sterling, IL steel mill, new UP/BNSF connection, coaling tower, Rochelle?)
Hmmmmm…thought I had some shots of the coaling tower there, but can’t find them on the hard drive. They must be on film (man I need to get a scanner!)
Anways, here are some shots of the remnants of the 0-8-0’s that were mentioned:
BTW, I asked before, and no one knew. Anybody have any clue just who Ken Marks is?
If the truss bridge you are referring to is at Galt near the 0-8-0s, it was damaged in a derailment in May 2005 and has been replaced by the girder bridge above top. The bottom photo is the wrecked double truss bridge, shot from over 1000 yards away with a 750mm lens. Here are some additional photos of the wreck:
http://s-scale.org/albums/v/friends/philk/galtwreck/?g2_navId=x3b6a8bf7
And here are some pics of one of the former GTW 0-8-0s and the Nelson coaling tower over the UP Overland Route. CTC east into Chicago starts at Nelson:
http://s-scale.org/albums/v/friends/philk/galtnelson/?g2_navId=x3b6a8bf7
Pop Z
Perhaps, a cousin of Kilroy?[:o)]
Yep–Nelson!
Pop, the bridge I was referring to was the one over the Rock River between Nelson and Sterling. I thought about mentioning the Galt incident, but decided that enough was enough. Here’s a shot at Nelson–the signal array I was referring to was behind this, and facing east. Don’t know if it’s still there–haven’t been west of Rochelle for a while.
Also, Pop, although Nelson is where the CTC historically started, it’s now CTC all the way across the state, and then some.
http://www.railpictures.net/viewphoto.php?id=143932&PHPSESSID=d97b34f49f017e8ba0bd99f19386aaca
That bridge over the Rock River is hard to get to, I think. It is visible east of a street that dead-ends at the river at a boat launch, IIRC.
Thanks for the heads-up about CTC running across the state. So I guess for nostalgia (or via apathy) there’s still a sign at the base of the signal bridge at the grade crossing east of the coaling tower at Nelson that indicates the beginning of CTC (this is an extreme blowup):
Or perhaps just for that track. I’d have to look at my tt to confirm, but I believe that at least one of the four tracks has lost its main-track status. There would have to be a sign like that somewhere, for trains coming off the Peoria Sub.
I have to go back to Nelson–my last time there was on a Sterling-to-Lombard bike trip, about nine years ago (oops, scratch that–we came back through there after checking out the wreck at Galt).
Since I’m not a photographer, I don’t worry too much about getting close to the bridge for using it as a prop. However, there’s a park in Sterling (can’t tell you the name; it’s near the east side of town, not too far east of the Dillon house/museum) where the tracks go nearly beneath you on a hillside, and you can see them curve away to the east and cross the bridge.
By the way, J-class nailed all of the hints as well, in his correct answer. Congratulations!
