The 11 Myths of Model Railroading
#1 – Zero maintenance layout (2200 sq ft layout) – You can’t maintain a large layout by yourself
#2 – DCC 8 amp boosters and welding engine wheels of the engine derails
#3 – Track Cleaning – Never again!
#4 – Reverse Loops – Using a toggle switch with DCC
#5 – Not removing ties on flex track
#6 – IDC connectors - #M scotch locks/Suitcase connectors for track wiring-NEVER
#7 - The Rolling Stock Truck Tuner tool & why do you need one
#8 – Soldering Track Joints
#9 – Homasote Expansion vs Wood
#10 – DCC and you have to modify the turnouts – YOU DON”T
#11 – Homasote Cost – making a mess when cutting – You Don’t have to make dust when cutting
PLW the MRR Myth Busters – #3 - The Myth is:
You have to clean your track all the time
No you don’t! This Myth was busted back in July of 2003.
It has been 35 months (that’s 1 month short of 3 years now) since I have cleaned ANY track on my home layout (and we run OPs sessions every other week)!
I had a Mini OP in April (2006) and did not waste time cleaning my track for that and had 24 operators in to run the layout. All of the sound engines ran great!
So what is my secret? Metal Polish!
I don’t use sanding sponges or blocks, erasers or any kind of Alcohol, paint thinner, Goo-Gone nor any other liquid. Neither do I use any kind of cleaning car.
Just used a little metal polish on an old piece of HO cork and hand rubbed on the rails and then buffed the rails again with a clean piece of cork.
Prior to the metal polish I was spending hours cleaning the track to get ready for an OPs session. And then we had to keep cleaning the engine wheels several times through out the evening OPs. And I had every type of cleaning car there was and none of them did any good as I still had to clean the track over and over again. I was not happy way back then!
