The 11 Myths of Model Railroading
#1 – Zero maintenance layout (2200 sq ft layout) – You can’t maintain a large layout by yourself
#2 – DCC 8 amp boosters and welding engine wheels of the engine derails
#3 – Track Cleaning – Never again!
#4 – Reverse Loops – Using a toggle switch with DCC
#5 – Not removing ties on flex track
#6 – IDC connectors - 3M scotch locks/Suitcase connectors for track wiring-NEVER
#7 - The Rolling Stock Truck Tuner tool & why do you need one
#8 – Soldering Track Joints
#9 – Homasote Expansion vs Wood
#10 – DCC and you have to modify the turnouts – YOU DON”T
#11 – Homasote Cost – making a mess when cutting – You Don’t have to make dust when cutting
PLW the MRR Myth Busters – #8 - The Myth is:
You will get track kinks if you solder all of your joints
I have soldered all of my joints and have had no kinks in my 2800 feet of track. It has been down now for 5 years and if I were to have problems they should have showed up by now!
I use is 7/16 OSB (Orientated Strand Board) for my subroadbed. Now I know that this just goes against the norms but then again I have had no problems. I also use Homasote on top of the OSB and then use cork under most of the mainlines and passing sidings.
The OSB is painted on the top and sides with the moisture barrier on the bottom. The Homasote is also painted. Now why don’t I have the normal problems that others are having?
Could it be the OSB (due to the large wood chips with the grain set at many different angles?) Maybe the OSB expanding in all directions instead of just one as with dimensional lumber.
But the main thing to remember is that it is working. I run a dehumidifier in the summer and try to keep the humidity below 70% and in the winter I try and keep it higher than 50%.
The real answer is controlling the Humidity in the train room!
All of t
