The ATLANTIC CENTRAL plan is posted!
It seems in the discussions on this forum there is sometimes an “us vs them” reaction about larger layouts. Just read any thread about curve radius, turnout size, train length, signaling/CTC, etc, and you will find several people suggesting that only 1 in 100 model layouts “fills a basement” (or barn), and the rest must do what they need to do - maybe so.
There are people in the “less is more” camp, people in the “Moores Law” camp (some is good, more is better, too much is still not enough), and everywhere in between.
Now, I understand that not everyone has the time, room, resources, motivation or even the interest to build a large layout.
I’ve seen many a modest sized layout that displayed exceptional model work. Size is not the measure of the quality of a model railroad, nor should it be.
I have been the subject of more than a sharp comment or two, partly because I have been blessed with a large space in which to build model trains and I advocate for large curves, longer trains, etc.
But I think it is important to take a minute and explain my approach to that large space.
My goal with a large space is not to make the layout more complex, or model more places, or squeeze in more features.
My goal is to better capture the immensity of the prototype.
Sure my distances are still compressed, my curves are still sharper than real mainline curves.
But that is how I use the extra space - not adding a second freight yard, but by making the only freight yard bigger, more relistic, more able to handle train lengths that are more realistic.
So while my layout may be “large”, it is by no means complex for its size.
Example - if one builds a layout with an 8 track double ended yard that is 12’ long, he will need 16 turnouts. If the next guy builds his 8 track yard 20’ long he still only needs 16 turnouts, and about 64’ more track.
The first yard will handle 18 ca
You are working within your limits of space, time, budget, experience level and spouse support. So is everyone else.
You are blessed with an abundance of benefits. Unfortunately, not everyone has the level of abundance they might like to have so they work with what they have. I would guess that your first layout would fit in a small corner of your current layout and was limited in many ways. Many people asking questions today are on the front end of the learning curve as you were at one time and they rely on people like you to help them move up the ladder until they can create their own empire.
Your generous help to them is always appreciated.
Hi Sheldon:
I don’t recall seeing any diagrams of your new layout space, but it sounds to me like you are in a pretty good place both house wise and layout wise. Yes, it will take time to set up your new layout. That is a given in the hobby. I’m sure that you will move things forward as expediently as is possible.
If you have posted pictures of your new layout space, please post a link to them.
Do keep us informed. You are a knowledgeable model railroader. I’m sure people will learn a lot from your progress.
Cheers!!
Dave
Since you wrote “barn”, I’ll jump to the conclusion you are talking about me. If that is truly the case, I said “probably 1 in 50”. In any case I don’t have an us versus them attitude. My comments were only related to DC versus DCC, and my opinion that many home layouts are not large enough to require functional signalling (CTC) and the wiring complexities required to install it.
And I am not going to debate the difference between large and complex. Both a large layout and a small layout can have a simple or bowl of spaghetti track plan depending on the owner’s preference.
Regarding broad curves, large number turnouts, and so forth, yes that is all achievable even in a small space. Unfortunately most (all?) the layout plans I’ve seen in MR and elsewhere with that criteria become so simplistic that they don’t do anything for me.
I suspect that the majority do believe that bigger would be better, only because there are more options for a bigger space. But with all due respect to Mr. Moore I am stuck with what I have. Home Depot does not sell a space stretcher. So to have the ability to run a shortened train around the walls requires the use of sub-optimal radii and lower number turnouts.
So my takeaway from your comments is that if I can’t meet the stated ideal layout criteria I shouldn’t bother at all.
[quote user=“maxman”]
ATLANTIC CENTRAL
Thanks Dave, no pictures yet, but I will put some up when I can.
Sheldon
Well, this past year I moved into a single story that is 2300 sq ft. The basement is the same size. It sits on 2 acres, over half is woods. I was already retired, but we needed to move to get my wife on one 1 floor instead of 2.
While I could use the whole basement, I decided I could do what I wanted in 17’ x 40’ - 680 sq ft. I have worked out a plan that is point to point with about 175’ main line. Since the Maryland & Pennsylvania RR was noted for sharp curves, I am planning a 27" minimum radius. This isn’t a problem because the Ma&Pa had small locomotives and short passenger cars.
This layout is smaller than what I planned in the prior house, but I’m in my 70’s now and I find that even retired I seem to have a lot of non model railroading activities in my life. So I figure I have a pretty good chance to finish this one (or at least get close).
Everytime I work on the trackplan I generally reduce the complexity. Originally, I thought I would need 75-100 turnouts, but now I’m looking at about 50-60. Construction should start this fall. My plan is to build the mainline first and then fill in the yards, spurs, etc. This way I won’t get bogged down in the details before I have a long run for the trains.
My goal is to capture the charm of a short line railroad. And I think I can do that - anyway I mean to make the attempt. Obviously, Sheldon and I have very different goals here. But that’s part of the appeal of this hobby - so many different ways to go.
They say you need money, time, and space for this hobby. I have had all of these at one time or another, but somehow I have never managed to have all of these at the same time. But I still enjoy the hobby within whatever my limitations are at the time.
Paul
Paul,
17 x 40 surely should do the Ma & Pa justice, no question, even in S scale.
As a resident of Harford County, I know the Ma & Pa history pretty well. In fact the home we are leaving is in Forest Hill, and the tracks ran right behind our house.
Best wishes for the new layout,
Sheldon
I’ve seen some ‘small’ layouts built in big spaces with tight curves and jammed-together track and structures, and ‘big’ layouts built in small spaces with flowing, spacious scenes.
Before you get to building, though, it’s a good idea to herd all the furnaces, air conditioners, water heaters, laundry machines, sinks etc. into their own corner of the basement.
Have fun with the new project.
The other day I bought a cap to protect my balding skull from the bad effects an overexposure to the sun can have. Somewhere on the sticker it read “One size fits all”. While this may be true for caps, this isn´t true for model railroaders. They come in all shapes and sizes, from different walks of life and each one pursues his very own happiness with the hobby of model railroading in his very own way.
From that point of view, there is never a question of “something versus another thing”, be it the type of control, the choice of prototype or era, the size of a layout, the scale,or the type of operation.
To each his own, according to his needs, wants and means!
Having said this, Sheldon, I understand your question as a mental exercise for yourself, for which you are gathering opinions before you decide which way you´ll be heading with your new layout.
I never had the space nor the means to build a layout which would fill a spare bedroom, let alone an entire basement. Even if I´d have had the opportunity for such a venue, I´d doubt that I´d have engaged in it. I just can´t picture myself building a layout that may take a decade or more to bring it up to a state in which I would begin to enjoy it. But that´s just me.
I assume you are retired or will retire soon. While this adds quite a bit of time you can spend model railroading, don´t forget to key in the fact that family, home and garden will require a lot of that extra time. I have seen many a marriage fail shortly after “hubby” retired and spent most of the time with activities not involving the family. For this reason as well as the time we have left on this planet once we surpassed the magic “60”, I´d definitively vote for “big and simple” and not for “big and complex”!
Ulrich,
I’m not retired yet, but the wife is. And her health issues are one of a list of reasons for the move.
There really is no question in my mind, this was the goal of the previous layout, it will be the goal of the next one.
“garden”? if you mean vegetables, we buy them…if you mean flowers, the new has has way less “gardening” but a little more grass mowing then the big Queen Anne…I have a machine, a big enough machine.
Complex - yes I started down that road once about 23 years ago and stopped before it go too far along…
Family is always first.
I think the main reason for my post was simply to share my thinking, and promote a better understanding on here of different approaches to the hobby.
I know my approach is in many ways not “typical”.
Take care,
Sheldon
Which I am thankful for, as my own approach is very different from what usually is shown or discussed here. My illness has forced me to give up on model railroading as it is commonly understood here. The only way to stay in the hobby was to go back to my roots - a Marklin HO scale tinplate train set.
I get what Sheldon is saying. I just might not have started the thread with the “us vs. them” line which is sure to provoke defensive reactions.
I have what would be termed a large layout in an unfinished (but temperature and moisture controlled) basement. Being retired, I have the time and finances to support my interest in the hobby.
I agree with Sheldon that size does not necessarily equate to complexity. I chose size because I have a passion for large downtown passenger stations in the 1950s, and it takes a lot of space to model such operations.
While I am forced to rely on selective compression even with my large space, it takes a lot of room to model an area like Dearborn Station in Chicago with its six major railroads using the station, plus its 12 large freight houses, coach yard and engine servicng facilities, and freight yard.
My last layout was too complex, what with control panels, double ended yards, Tortoise controlled turnouts, etc. I am in the process of bulding a new layout on the same basic footprint, but with a lot less complexity than the old layout. For example, the coach yard and freight yard will now be stub end. My turnouts will no longer be Tortoise controlled Atlas turnouts but rather spring controlled points on Peco turnouts requiring nothing more than my index finger to activate.
Larger layouts don’t have to be complex and they don’t need to follow a ‘more is better than less’ approach when it comes to structures and yards and number of locos and rolling stock. Larger layouts simply need to take advantage of the larger space to more closely simulate the prototype.
Could I be happy with a smaller layout? Dunno, and I don’t intend to find out.
Sheldon,I would rather have a small compact ISL that I can build and enjoy in a short time since I know first hand how fragile life is after knocking on death’s door twice…
Regardless of size a modeler should never plan a layout while singing here a track,there a track,everywhere a track, track-rymes with Old MacDonald farm…
I’m a firm believer that a train should pass through a scene once and CTC single track main line with passing sidings is the best way to achieve that goal.
I have a small 55 sf layout, a walk in U folded dog bone. It is my third and last layout, and I will be tweaking it for the rest of my life. Based on lessons learned from my first two layouts, the first was an 8 X 4 and the second was a complete disaster and never finished, I designed it with several factors in mind.
From the very beginning I did not want to fill up my railroad room with the layout. Secondly, I did not want to spend time, time, time, and more time cleaning track. My layout is freelanced but designed to offer some prototypical operation with six industrial spurs, a modest yard and two sidings. Although I usually operate as a lone wolf, the layout is set up to provide for three operators, two running trains and one switching the yard.
Another concession I made due to space was that I would only be able to run short trains, no more than 6 maybe 7 cars plus a locomotive and caboose, with maximum 40’ rolling stock.
I have several other interests to keep me busy…golf, travel, photography, spectator sports, all of which consume a portion of my entertainment dollar.
If someone wants to have a big layout, I say more power to them if that is their interest in the hobby. I enjoy playing with my trains as I am sure that there are any number of owners with mega layouts enjoy having lots of people over on a regular basis to operate their layouts.
I’ve been casually looking myself, even though I haven’t even been here 5 years yet. The house is plenty big, I really don;t need a larger house, but as a riased ranch I loose over 20 feet for the garage, which is huge - it’s listed as a 2 car garage but WITH stuff I am still able to get 2 cars and my truck all inside it. I love the pool, I’m in it all the time - except I am usualy the ONLY one to go in it on a regular basis. The maintenance isn’t too bad, and I don;t spend a fortune on chemicals each year, but doing the work and then being the only one to enhoy it is already starting to get a bit old. Then there’s the land - I have plenty of space for my (small) dogs, but the front in particualr is on the face of a steep hill and I am not able to cut the grass so I end up paying someone to do it. Yet riding around on the tractor cutting the grass is something I actually find enjoyable and relaxing. So I’ve been casually looking to see what comes up - I definitely want one floor (bad knees) and of course a basement - but I don;t really need a bigger house, just a bigger basement., A ranch the same size as my current house (1800 sq feer) with a full basemend, because the garage is to the side, would be fine. Flat land, don;t really need more than an acre, as long as it is realtively flat, and it doesn;t have to have a pool. Preferably an unfinished basement - to make this one usable I nmeed to rip everything out and redo what the previous owners did to get it in shape to be a suitable train room.
Just that bit extra - more logically laid out, would give me plenty fo space to build what I want without going overboard. I’d be able to keep it all on one deck, greatly simplifying things, and elminating the need for a helix.
My own feeling is that size of space for a layout, and even size of layout, is only one factor, and not a controlling factor, in creating the impressions of realism that we all seek. I have been to huge layouts that were so crammed with track that the first impression one gets is not unlike that of the old Lionel display layouts - it somehow can seem, well, tiny! Related to that, sometimes selective compression – not so much of this or that structure but rather of entire scenes: impossibly short city blocks, utility poles far too close together, narrow roads and sidewalks, too many vehicles and too many pedestrians, that sort of thing – gets taken too far and that also creates an impression of lack of realism.
This may sound odd, but psychologically, I find that cramped aisles themselves make a layout seem cramped and thus unrealistic to me. Related to that, track plans that place distant parts of the layout in close physical proximity – end of peninsula “blobs” near each other for example – also detract from realism when you can see too much distant real estate all in one glimpse.
And at the risk of annoying many modelers including some famous “taste makers” in the hobby who worship double deck layouts due to the length of run they provide, to me I see no virtue in studiously avoiding insincere track plans that have the track going through the same scene twice or thrice, yet have double decks with track supposedly miles and miles away, but just a few inches apart, up above or down below. One is condemned and the other praised by these taste makers. My eyes and thus my brain are NOT fooled by this.
Not all might agree with me but I think a layout that takes selective compression with a light touch, and which at least attempts to capture some sense of the vastness of space around the railroad, can look and feel “large” almost regardless of size. Perhaps not an oval but an L shaped switching layout tha
Yes. Exactly. I’ve been saying this for years. Well . . . except for the do over part.
When I look at at track plan in MRR (HO scale, of course) I can easily imagine it in N scale. Exact same layout, exact same footprint. But more space. Just loosen the belt a little.
And, I also agree with Dave’s comment about aisle width and clutter.
Robert
Here is some of the detailed criteria for the new layout:
No double decks, I agree with Dave Nelson. I tried it and did not like it.
No running thru the scene twice.
No hidden track that is hard to access, no staging “under” the layout, with small clearances to work on track or reach rolling stock.
In fact, my staging yards will be behind back drops, mostly wide open to the top, and many will have “operator only” access aisles.
Gracious curves where ever possible, 36" radius will be the MINIMIUM for the mainline, most will be in the 42" range.
Deep scenes to allow plenty of modeling of what is around the tracks - without crowding things. Typically scenes will be 30"-36" deep, some deeper.
Wide viewer/operator aisles, 48" is the minium goal.
More later,
Sheldon
I pretty much agree with what Dave and Sheldon just wrote. It’s nice to hear that there are others who have problems with multi-level plans.
One exception is that I have 48" minimum mainline radius. Right now, I’ve got some Long Runners on a curve, and the “bridging” trailers STILL don’t look right–too clunky.
David Rose had a nice trackplan here on the forum, where exposed curves looked maybe half as sharp as concealed. Maybe even softer. I think it was Armstrong who opined that some very broad curves out in the open looked very nice.
Ed
