The Big Picture?
Hi everyone,
I finally got to do some work on my layout this weekend and while I was working a question came to mind. The question was this, How should I plan for future layouts? Here are some things to think about. My current layout is only 2x4 feet and is n scale. I would like to build a bigger layout however time a space are big factors right now. So, my 2 thoughts are first, plan a layout in a specific space and track plan etc. However, this seems impractical because I do not know what space I will have. My second thought was pick element that I want in my future layouts (industries, scenic feature, etc.) and design a loose track plan that I can fit to what every space I will have in the future.
Thanks in advance
Sean
My only advise would be to make this 2x4 layout not so permanent. In other words, build it so you can remove all your track and scenery so you can use it on the next layout.(don’t glue things down permanently) Odds are you probably wouldn’t use this as part of a future, larger layout.[2c]
I’d agree. 2x4 isn’t very large. Plan to use adhesives that let you pull the track up and re-use it some day.
The most “re-usable” things you will get by building this layout are skill and knowledge. In the long run, that will be worth more to you than the track and scenery.
I downloaded the free Atlas Track Planning Software. It allowed me not only to plan and fool around with the current layout, but incorporate future expansions. That way when expansion # 1 happens I hope to save time and money by not having to rip up what I currently use. So the spurs to nowhere now, will be incorporated later…
Your idea of building separate design elements that can be strung together along a route of indeterminate length and configuration is a good one. That way, the size and shape of the final layout will be immaterial. (My ‘expected to be against a wall’ end of the railroad module will end up as one side of a peninsula - which won’t bother anything.)
Since you are in N scale, you might give some thought to building one or more N-Trak modules as part of your design element collection. You might also give thought to building some which would function best as against-the-wall shelves, to be viewed and operated from one side only.
Just my [2c]. Others will have other suggestions.
Chuck [modeling Central Japan in September, 1964 - in Twice-N scale (1:80, aka HOj)]
