OK, Big Boys, Challengers and even RS11’s may be nearer and dearer to the hearts of everybody on this forum, but did you know about these ALCO products?
These are V16 251C engines and the vehicle in question has two per 1000kw generators which power 16 traction motors and were delivered in 1965.
I’m not sure what it might be (a missile transporter?) but I doubt that it was as big as the US Navy’s “Newport” class LSTs which had six Alco 16-251s for propulsion, three per shaft, and at least three 8-251s for on board power.
The “Mammoth Crawler” originally used to move the Saturn V/Apollo and its associated launch platform from the Vehicle Assembly Building to the pads at Launch Complex 39. Later used for the shuttle.
I remember reading an April issue of Road & Track where they did a “road test” of said beast.
Penny, I think you have that backward; it’s two 1000kw generators per 252 (there are just under 750 watts in a horsepower when you are estimating)
I confess I like the picture of this engine room in a recent MR thread taken looking ‘the other way’ with an attractive young lady providing additional interest.
One of the details I remembered from the R&T “Road Test” was that the Crawler was powered by a pair of Alco engines. In line with the April 1st theme of the article, the author(s) were having a bit of fun with the purpose of the crawler and ending the article stating that it was used to move condominiums around. Funny thing was that the condo looked like a Space Shuttle…
With the first Saturn V llaunch in 1967 and the last shuttle flight in 2011, the Alco’s were in use for at least 45 years.
Have to admit that is pretty darn amazing. I did not know what powered those crawlers. Thanks for this Penny …excellent information and pics.
M636- 3 of those per shaft…Wholly Mackinaw! Follow up questions for you-- how do they determine 3? If it were 2 would the shaft driving the propellers be substantially different ( slower)…and how do they connect three of them powering one shaft/propeller.
Perhaps interesting: I believe that even though the Super Crawler mods involve the new Cummins engines, the ‘revised’ design still features upgrades to the ‘Alco E1/E2 Engine Panels’ so the heritage survives.
But the clip I provided IS from the 1960s, chosen to forestall precisely that possibility. And has the launch stack loaded, in case that made a difference with the smoke.
Mind you, that doesn’t rule out a certain amount of cold smoke at starting, but I don’t think that is the burning-of-Rome overfueling smoke that most of us know and love in association with Alco power…
I think the PA’S were famous for smoking. Maybe that’s why the late DPM dubbed them “honorary steam locomotives.”
Anybody recall the photo of two Alcos heading an excursion train in winter, I believe? Not sure if it was in CTM or another magazine. The two Alcos were smoking so much that the photographer almost didn’t notice that engine number 3 was a steam locomotive!
Both the 244 and 251 were prone to smoking, but this was an artifact of the turbocharger design and the main generator/alternator loading rate.
Definitely cured with air motor/overrunning clutch on turbo. Also by accelerating the engine at part load to just above desired ‘run’ rpm then loading with governor set slightly high until fuel rack advances at proper exhaust flow through turbine.
Multiple smaller turbos as used in other applications would probably work too, but the economics of this anywhere in the Alco turbo era would not have been good. (compare the Elliott/AiResearch era on UP)
Whether the CT was jacking or moving, the load would have come on smoothly, hence little smoke. I would like to see the operations instructions to confirm. Who here is already a L2 member?
It didn’t have to be a PA to smoke, I’ve got a color book on the Susquehanna published in the early 90’s with a shot of some late ALCO’s smokin’ up a storm on start-up.
