the dreaded 4x8 (but will expand eventually)
So if anyone has been following my model railroading, I’m eventually goingto be building a layout around the outside of my 12x10 shed. eventually. The shed needs some work, and I’ll need to run some power out to it.
In the mean time though, I want to get something set up to run some trains. I have a 4x8 table that has 2 ovals already tacked down on it, with a little cleaning and some extra nails here and there, I can get it going quite easily.
I’m posting because I want to get something going soon in my garage until I get the shed fixed up and electricity out there.
I was thinking with that in mind, would something like a 5x8 work for in the shed? Just something I can build in the garage using the 4x8 i already have, while I wait for funding from the wife to fix up the shed. And once the shed is fixed, just move it on out there?
Garage layout can’t be permenent sadly, but while the garage is a mess until the shed is fixed, I can set up something. It’s also my workshop right now as well, so I have some cleaning to do anyways
opinions on what would fit in that shed? I figured maybe a 5x8 or 4x10 would work in the shed? i think either would let me work around in there i think, more so the 4x10.
You started this discussion on your earlier thread. I think it was agreed that an “island” or “table top” layout would be fine, with one short side against a wall, with access to the other 3 sides.
It would be easier to move this from the garage to the remodeled shed, than an “around the wall” type.
Mike.
I have a 4x8 I can use, ready to go. I was just wondering how much bigger should I make it, if at all? Or cut it down to give more room inside. The shed it a little short on the edges, so in there an around the room would be best, but having it in the garage first before the shed is fixed won’t really work.
Hi there. Given that this is a temporary layout, I would go with the 4X8 and have fun with that. Why cut up good lumber if it’s temporary? And there are a guzzilion 4X8 plans out there that are fine. I say go for it, keep it simple, have fun, and plan for the real empire to come…
Simon
You can build a ‘‘around the room, shelf’’ in sections. Say 4 to 6 ft long,as wide as you want/need. Build as a free standing unit. To fit the shed.
When the shed is ready, just move the sections into it
Just because you have the 4X8, don’t mean you have to use it. Ripped in half would give you 16ft of 24in shelf.
If you are looking for operation, you could check out my layout here which has provided me with many years of enjoyment and relaxation.
If I had the option I would go either 5x8 or 4x10 (more likely the latter and slew my front tracks slightly outwards so that it did not seem quite as geometric from the front and give more appearance of length.
I use a lot of imagination to run it and as a result I have 7 imaginary stopping points with 5 on my “mainline” doing a lot of duplicate, triplicate and “five-plicate” with the trackage but I am heavily into duplicating prototype operations rather than operating to a card system.
There is a PDF of the original article I built my layout from if you care to send a PM, I am quite happy to share!
Cheers from Australia
Trevor
Hi Wdodge0912
Nothing wrong with 8x4 tons of plans out there to choose from. But is it a temporary layout, or do you want it to be part of the later shed layout? That is the killer question and will have a big impact on design and construction.
regards John
I guess that’s the question I have, and am seeking advice on
Should I just run it as a temp layout, pretty much just the double ovals as it is now, or should I build it for the shed? If I build it for the shed, should I make it free standing as I would have it, or change the “around the wall” layout to an island style that I can move to the shed when it’s fixed up.
Your shed seems small as far as sheds go. I would mark out the shed size in chalk or with string lines on the ground and see if the 8x4 can be a peninsula with a layout running round the walls and still leave adiquate aisle space.
In a shed the size you quote the last thing you want is an island layout it needs too much floor space and would be difficult to reach across.
However a round the walls with a peninsula could work well maximising the avalable space for a model railroad and still leaving enough room to move around it and work on it or play trains.
If a back scene or high enough mountain range runs down the center of the peninsula you can have a station each side maximizing operational and scenic potential as you see fit.
You don’t realy want to be trying to reach more than three feet across a layout to do anything.
If it can work as a peninsula I would build it as a layout making sure the “wall” end will conect into the final plan, but you can still run it as an 8 X 4 for now trying no
[quote user=“John Busby”]
Wdodge0912
John Busby
Hi Wdodge0912
regards John
Nothing wrong with starting off using a 4x8’ layout. PLENTY here have and then “upgraded” to a basement empire. They apply valuable lessons learned from the experience. I did that on my 2nd layout. The confidence and happiness levels were so much higher.
Here’s an idea I came up with talking with my Grandpa about a layout.
The idea is 2 shelf layouts. 18" by 8ft. What I would do is have it so I can take them off the wall, and set them on an end/support section to make them into a loop. I’d also have legs unfold or a saw horse set up to support it in the middle of the long 8ft sections.
I’ve attached a picture of the idea I had for the layout sections. I am going to keep playing with it to maybe have them further break down into more managable 4 foot sections. If i do that I could go with 2ft wide for some extra width for buildings.
Or if I felt.like doing the engineering work, have the yard section mounted on the wall. Have the curve sections fold up, and have the center on the opposite side fold up, but stay upright as well. Not sure how Inl would do that, but that way building height wouldnt matter on the center sections, and I could leave trains on that lower section, and operate that as a regular shelf style layout I if didn’t want to set the whole thing up
the dreaded 4x8
And why is the 4x8 dreaded for HO? Tight curves.
My guess would be what I choose to call trainset track.
More particularly I believe in the USA R1 is 15" fifteen inches or UK 14.5/8" fourteen and five eighth’s of an inch which would be very restrictive on what could be run.
I would also think short trains and other restrictions plays it’s part as well.
Not to mention most people including me want trains that are longer than train set trains.
I can’t say I have seen many short line model railroads whitch with a bit of malice of forethought could idealy be built on an 8 x 4 and be a proper model railroad.
I have to say I have seen an 8 X 4 plan that I nearly built as a “large” HOn2.1/2 layout following same size and track formation but using narrow gauge tracks, but lots of aligators did not seem like fun[:D] nor did making lots of the kind of trees that grow in a swamp which I am totally unfamilier with.
The scale can play a part as well in the 8 X 4 question as well.
regards John
That’s kind of a chicken and the egg question. Which came first, set track to fit a sheet of 4x8 plywood or visa versa.
Aye. As is always the case. To me the main use of a 4x8 layout is lack of space and a way to learn some basic layout skills before moving on to something bigger if space allows.
The O-36 three-rail O-Gauge trainset came first, and fit nicely on a 4X8. IMHO, the 18” HO trainset radius was a response to this. But the more-to-scale HO equipment didn’t work as well as the toy trains.
Maybe. An HO “4X8” requires an 8’X10’ space at the very least. I think it’s mostly about being unwilling to cut wood – just my opinion.
Hi cuyama
Yes to some degree convienience of construction comes in to it being a standard size.
But back in the day when the 8 X 4 scale starter or toy railway concept came about.
People worked longer hours as standard and had less relaxation time, what constituted a model railway then we would call a train set today.
There was a genuine need for a propper suport system that was a quick and easy way of getting a proper suport system under the railway thus the 8 X 4 was born.
What we recognise as a model railway today did not get into full fruition untill world war two or there abouts and war time shortages helped push that along.
There have been a lot of inovations since then that allow us to build more complex layouts, than they could dream of and they would call it science fiction or just a case of that will never happen no one will ever have the time to do it except maybe big name millionare
The 8 X 4 train table goes back to before all of us and I do mean all of us where born
regards John
I also would stick with the basic 4X8 sheet and expand later…There are thousands of plans out there for 4 X 8…
