Hi all I am out[:(]
Mine will break rules 3&4 and doesn’t have enough
room to make it obey the rules.
Mr Ratsun sir have that disqualified stamp ready as if the drawing arrives in time I am going to make it anyway[:D]
I can gaurntee some one will not believe there is a prototype for it[:-,]
TJ would probably make it larger
Mount Canons and find a way of adding rail guns and a parrot to it as well.[swg]
regards John
Puckdropper,
the rules say “It needs to be powered, you decide how”. Pretty clear to me.[swg] Rules also make no reference to survivability after one lap around.[:-,] I have plans, oh yes, I have plans…[X-)]
hi all
Well found a scource for the drawing just have to wait for it to arrive
Have heard domestic bleach will bend Balsa is that true or a fairy tail??
regards John
John
I bend bass wood and ply wood with a mixture of ammonia and water. You will need some sort of former to bend the wood around. With any luck you will have a pipe or can around the house that is the right size. I bent a piece of 1/16 inch ply around a radiator pipe to make the roof for the freight motor that I am working on now. Please do not mix ammonia with any chlorine product or you will get MUSTARD GAS, which killed thousands in the First World War!
Bob
John,
Pay no attention to Bob, mix all the chemicals you want, it’s all OK and perfectly safe[}:)], Union Carbide does this all the time with no ill effects, well, um, there was that one little problem in India…
Yes, bleach will do a nice job of softening balsa to make it easy to bend. I do this all the time on my RC planes. A mix of about 15 ml of bleach to ½ pint water (5 ½ jiggers)
ought to do the trick.
Gauarranteeeed he’ll get those army cooks to feed him something that would make enough gas to power the QE2 around the world, let alone a little model around a layout!
Just hope he warns Michelle before he comes home that night!
Hey guys,
This oughta’ be a blast. Sorry I can’t join in for times sake…too much else to do before the snow flies. Can hardly wait to see what you guys come up with! Later eh…Brian.
