As stated in another thread, I just got my Tier 4 gevo from scaletrains, an ET44C4 to be exact. After listening to it and running it for a bit, I haven’t heard any GE “whoop”, and I wanted that sound. Is it because GE’s newest loco’s no longer have it? Or should I listen more patiently?
F20 should toggle the compressor. In the ESU demo here at about 00:50 seconds I hear the compressor kick on but no “whoop” as I’m familiar with on the GE “Genesis” locomotives.
http://projects.esu.eu/projectoverviews/search?type=diesel&q=tier%204
I don’t exactly know, other than a Westinghouse 3CDC compressor, what the ET44C4 type compressor is. They all seem to be motor driven rather than off the prime mover drive shaft as in the past. I’m also not sure which compressor types are available on the particular LokSound decoder that ScaleTrains uses. Presumably they would already have the proper type selected in a factory installed sound project.
Good Luck, Ed
Yeah, I figured out the F20 compressor thing, but all I have heard is that sound that sounds like a cross between a baby rattle and some sort of musical instrument…
Thats why I’m confused.
I’m not in front of my Loksound file info at the moment. It seems to me that the compressor type is part of the prime-mover sound file and is not selectable. For instance, the Dash-7 file specifically mentions the “whoop” compressor:
In the Mid 1980s GE changed it’s 16cyl FDL design to include a different exhaust silencer, a new electric compressor often known as the “Whoop compressor” and changed some of the electronics of their locomotives. These differences among a few other led to a distinct change in the sounds from the GE 16cyl FDL often found from the U25Bs on through the Dash-7 series of the Locomotives.
The Gevo file seems to have the shaft-driven compressor, as you have heard.
Good Luck, Ed
This is distresing news. Hopefully a sound file update can be provided to rectify this, if indeed the ET44 has a “Whoop” compressor.
Until then, an “analog” solution is to have bean soup before operating sessions.
Dave Nelson
But the question that isn’t answered here is do any real ET44s actually have the old “whoop” compressor? If they’ve switched over to a different compressor, then it’s correct and there’s nothing to rectify.
Maybe we should post this question on the Trains magazine Locomotives subforum…
Oh yes please do. I am still curious. Mebbe GE respones to emails from prototypically interested modelers too?
What is the difference between an ES44 and a ET44?
The ES44Ac has the “whoop”: https://www.youtube.com/watch?v=8PZ8fH_sBqg
I believe that the Scale Trains loco comes with a Loksound V4 decoder, not the select decoder. If this is the case, you should be able to change the compressor sound to whatever you want it to be, assuming that ESU has the “whoop” sound file somewhere.
But more of what I want to know is if the prototype ET44C4 had the whoop. Otherwise there is no point in changing the cv.
I posed the question on the Trains magazine Locomotives sub-forum.
No solid, definitive answers yet, but someone made a comment on Australian GE locomotives that sort of leads us to believe the compressor was changed:
Here’s a link to the thread:
Thanks! Hopefully we get a definite response. Otherwise its back to teir 3 models to capture the classic whoop.
Once again, what is the difference between a ET44C4 and an ES 44?
An ET44C4 has four AC motors, an ES 44 can have six AC motors or six DC motors unless it is an ES44C4 which has four AC motors.
The ET44 looks much more like an ES 44 than it is…
The engine is entirely new with few interchangeable parts and has two turbochargers instead of one. The cooling system is much larger.
But the point I made at the link above is that GE changed the control equipment that operates the electrical air compressor, so the compressor does not make the sound any more.
In Australia we had 120 model Cv40-9i units which all made the “whoop” sound.
Later GE locomotives did not, and the Cv40-9i units were all rebuilt with updated electronics, but kept the old compressor. But the whoop sound went away.
So if ET44s have the same compressor control equipment as the rebuilt Cv40-9i, they would not make the sound.
The quick answer is to go out and listen to an ET44. There are hundreds of them.
Peter
Sorry that I didn’t respond to your question the second time, maxman. I haven’t been able to log on for over a week. I just managed to get back in today.
