the LION'S Analog Automation
Everybody had herd of it, but I made a web page that describes my automation.
Comments are always accepted.
ROAR
LION,
Now,I herd it and sawed it all,By the way,that timer,looks as though,it possibly,could have parts,from German code machine,used in WW2,The ‘‘Enegma’’ machine…
Cheers,
Frank
Cat,
I got a page not found error.
Mouse
Chip,
Maybe he somehow, did that on, poorpusse,for the mouses,LOL,
Cheers,
Frank
Got through this time. I gotta say, you put a lot of thought into this. Congrats.
Actually, I got the same error, I tried to look at the site while the page was still uploading.
I host my website on my own servers, and so it is just as simple as moving a file from one folder to the other, but I use the Web program to do this, since it keeps track of the whole web site, and corrects all that are affected by a change.
ROAR
This is really good stuff. As an EE I get a kick each time I think through your circuit diagrams. My (still coming together) layout is all-digital and I sort of miss working these things out. I suggest you also add the circuit diagram of the analog signalling/block protection system, it’s good work.
NP.
That will come, but it will be a separate page. The signal system still needs some work which is underway even now. It will be two pages, actually. One for the detection and relay controls and another for the construction of the signals for the layout. With over 200 signals on the layout, it will be necessary to take some liberties in order to get the cheapest signals possible. Even $1.00 per signal is far too much for the LION to spend.
ROAR
LIONS think outside the box![][][][][*]
Interesting! Your timer, with the metal tabs that look a little like the tuned comb or teeth of a music box, certainly looks similar, to my eye at least, to the timer that is part of a washing machine. As the timer turns it activates various circuits for the washing cycle.
Dave Nelson
HAY LOOK! Brian has new avatar. The other one did not look like you.
LION - Changed unless the Leafs Win the Cup or are defeated. I hold on to my illusions tightly.[;)]
Lion is one smart cat! [tup][:)]
Just what was your job on that Aircraft Carrier and is this where you learned to be so smart, or was it somewhere else?
Most important man on the ship! (notice that I did not say “officer”)
LION was a cook! You wanna eat, you be good to the cooks, else we will cut your rations back to government specifications!
ROAR
Well, Lion has cooked himself up a very impressive layout using great ingenuity and creativity. Well done.[tup]
