Hullo, it’s certainly been a while since I’ve said anything. Crazy crazy year, but I suspect everyone here already knows enough about that.
Something I’ve been looking at a lot lately are the varieties of compound locomotives used worldwide, including the various late nineteenth century and early twentieth century methods attempted in the United States and with my layman knowledge trying to think about what form of compounding works best in the United States (besides the matter of the mallet of course, think of this as a discussion pertaining exculsively with rigid frame locomotives).
The main problem with compound locomotives is that while they give the advantage of better thermal efficiency and reduce fuel costs, their arrangements often result in high-maintenance costs from relatively high numbers of components and complicated steam pipe networks, pain-in-the-rear end accessibility for certain arrangements, and in some cases the system was mechanically problematic from the outset (like the four cylinder Vauclain), to the point that either no profit was gained or indeed lost from experiments which were gambles.
From what I’ve reviewed, the more mechanically sound and efficient the system was, the more complicated it was overall and inaccessibility increased dramatically, along with the chances for something to go wrong. The main examples here would be the four cylinder balanced compounds with inside and outside cylinders, which if properly run (more that could be expected from the average United States driver) could give astounding fuel savings and at the same time were phenomenally smooth runners. The main problem comes from the complexity of the system, with two sets of valve gear inside the frames. Crank axles were required as well which spelled bad news in the U.S… Problem is crank axle assemblies from what I know simply often did not have the strength to withstand the forces distributed through an American locomotive. These were co
