The On-Line Article on Laying Flex Track with Caulking
I just finished reading the article on using caulking compound as an adhesive when laying flex track. This is a good technique and one I have used extensively, but now I offer an enhancement:
Use a little more caulk than the author recommends and then sprrinkle ballast into the wet caulk. (Buy the caulk in a dark color so that it will blend in nicely with the ballast color) . You may have to experiment to get the right amount of caulk, but once you’ve mastered the technique you will have a neatly ballasted roadbed with less mess than the usual diluted white glue method.
Dumb question here: I clicked the link for this thread, thinking I would be able to read the on-line article, but it just gave me the post by DonCameron. May I ask (without upsetting someone who has answered this question before!) where is the article on Laying Flex Track? And is it still available? Sorry, but I had to ask. Thanks!
Might be this one…
http://www.trains.com/Content/Dynamic/Articles/000/000/004/379dcjrm.asp
Looks like the right information to me! Thanks BaldwinJL!
I have a bunch of test sections of doing just that. it works to a degree…Finding the right amount of caulk is more difficult than i thought. it all depends on how you want it to look.
You have to remember that only a thin layer of balast will actually stick to the caulk, there will be no thinkness of balast. So, the balast will not fill up the area in between the ties making them “burried” in the ballast. I tried to use a lot of caulk, so much that the ties were sunk into it so that the balast was the right height when sprinkled on…it wokred well, until i touched it with my finger. Word of caution…Dont Touch it with anything! I messed up that test section with that one second touch.
Next issue, if you just sprinkle the balast on and let it dry, try not to touch it or let anyone else touch it after it dries. if you rub your fingers on the balast with any force, it will come off, much like how the sand comes off sandpaper after it gets wet.
I am still in the process of testing this all out. in theory it should work like a
charm, its finding that charm first thats difficult.
If you are not a huge stickler on the fine fine details, there is another method for balasting track that I learned from another member on this site.
He has painted his roadbed and then just laid the track on t
