The Trivial Pursuit Question from (The scrappers inferno): WHAT IS IT!!!
Hello one and all.
I am a regular over at the Atlas Board, a Trainboard member born and Raised so to say.
I have recently come upon a real stumper of a problem. I purchased a locomotive here a couple weeks past, and I cannot figure out for the daylights on the Espee what the heck it is.
My Valentine’s Day was beautiful. Instead Of having to deal with complex issues through mass expressions on afferction, I was able to take that resource and put it into a new locomotive, Aha aha aha!
The locomotive is rather nice in weight, and I really like the look of it. It is a nice small little 0-6-0 Fleischmann, or at least, it has a Fleischmann Coupler affixed to the brass frame that is under it. When I got it, I found it to be pleasently heavy. The Worm Gear is nice metal, as is the drive gear on the axle. I tried power, and soon found that the motor wouldn’t turn. In looking at the motor, underframe, and gear connection through the bottom, I notice that the underframe had been bent I.E the engine at one time fell or got crushed, with the main bend being centered somewhere over the rear driver/gear connection. In looking at the huge ding in the cab roof edge, I am guessing it got crushed.
Not a problem though, never a serious problem. I cranked those screws out, tore it down, and straightened the frame. Simple enough. Next, I again set power to the motor, and to make sure there was no wiring getting in the way, I disconnected the motor from the frame and from the wiring harness by resetting the solder point. At this point, the motor was entirely free of the engine.
I now tested the engine, putting power directly to the poles/leads/brush assembly; you know, one side in, one side out. It did not turn. I then set my fingers to the rotor, and found that there was resistance in the drive. In the next couple of minutes, I came to hate the designer of this locomotive motor, as it is awful. If you ever run into one of thes
It looks to me like the flanges are too small and the wheels too close together. The gauge should be at least 7/8 inch and preferably 1 1/4, or more.
I just checked it to a piece of Powerloc track. Thought the Flanges are about 1/16th one and inch (1-2mm) from being perfectly matched on either side, the rim is adequately matched. It moves through curves easily (moing mechanism with 0-5-0).
It has room in there, but at the same time, it remains comfortable on the track. I tested it on a switch, it makes it through beautifully.
As such, I conclude that the wheels are gauged to HO track.
Marklin shell on a Fleishmann drive?
