The Use of 'RibbonRail'
Just wondering if anyone has used ‘RibbonRail Track Alignment Gauges’ in HO Gauge? Thinking about buying some in various radius for curved areas of track. Just curious if it’s worth it to buy? Thanks!
I have several 30" radius and lots of 5" & 10" straight ones. The curved one are to make sure my curves do not slip under 30" radius, and the straight ones were used to make sure my yard tracks were tangent.
Jim
One of the very best tools that I have ever bought for my layout was the Ribbonrail Track Alignment Gauge.
The curved gauges come in 5" and 10" lengths. Buy the 10" length to make the measuring and forming easier.
I bought several of the curved gauges selecting radii for the 26", 28", 30", 32", 34" 36", 38", and 40". My curves on my double mainline are 30" and 32" with 28" on some sidings. So, I wanted a range of radii to confirm my curves. I use all of the gauges.
Ribbonrail also makes a straight track gauge, and it comes in 5", 10", and 24" lengths. The 24" length is extremely useful in setting lengths of flex track perfectly straight.
I highly recommend the Ribbonrail Track Alignment Gauges.
I bought a set of the Ribbonrail radius and tangent alignment tools and used them quite a bit – it has various radii and various lengths of tangent. For the stiffer brands of flex track such as Micro Engineering, I just ran the alignment gauge of the radius I sought through the piece of flex track over and over and over – it took a while for the flex track to “take” the radius. Similarly when laying track, I used the alignment tool where two curved pieces met, to preserve the radius.
Having said that, don’t expect perfection - you still want your radius drawn on the cork or other roadbed material as you lay the track and some “muscle” (gentle muscle) is needed to get a perfect radius curve. My pencil line also includes the easement curves on the ends of the curve.
I did the same when using stiff flex track for a tangent – ran the tangent through the piece over and over.
For “whippy” brands of flex track such as Atlas the curved or tangent alignment tool is used during the actual track laying. Some guys drill holes in the middle so that they can put in the occasional nail in the center of a tie for such track. I think RBL also makes a plastic alignment tool that has openings in the center for track nails if you use them.
There are now other brands of rather similar products although not in metal as is the case with the Ribbonrail. There are also similar products for N track.
Dave Nelson
Like Jim, I use my RibbonRail gauge to maintain minimum radius when laying flex track. (Unlike Jim, I don’t have the luxury of 30-inch radius, though.)
When I built my carfloat terminal area using Proto87 girder rail, I found the gauge to be the single most useful tool I had. It wasn’t the right size for rail-to-rail spacing, but the edges worked perfectly for aligning the rails section-to-section and maintaining constant curvature.
As for getting the rail-to-rail spacing right on the girder rail, there’s that other oh-so-useful tool, the NMRA track gauge.
I find the HO Ribbonrail gauges very handy, especially useful when forming Microengineering flex track and doing mock-ups. IMO, well worth the cost.
regards, Peter
Thanks everyone for your input! Looks like I’m off to the hobby shop to make some purchases!
I’ve had great luck with their products in N-Scale
Mike
I never did that, however, because I have hand laid some track, I have spikes and spiking pliers. What I did was slice off a “molded” spike here and there, use a pin vice to drill a tiny pilot hole, and the use said real spike to tack down the track, followed up with the traditional nail through the center of the tie to ensure that it stayed put. Good tip though, especially for those not already equipped with spikes and spiking tools. Just get a drill bit small enough to stay inside the gauge, but big enough to clear the nail head, line it up, and tack it in.
I have used them alot. I had only one curve that ended badly but it was my fault due to the s curve I needed, a very tricky area.
I have not used RibbonRail products, but have been well satisified with traditional methods of aligning track.
For curves, I solder the track joints to prevent kinking, then simply set the flextrack to follow the roadbed centerline, and if I’m off a 16th or even an 8th of an inch, it won’t be material even on the smallest of radius curves. For straights, I just set a straight edge along the edge of the ties to align the track.
I use Atlas Flex, glued to cork with caulk; 26" radius on the main.
Jim
And so I thought. But, a few years back I bought 4 Rivarossi passenger cars, which are rated for 18 inch curves. They meant 18 inches, not a bit less. I think that’s when I bought the RibbonRail gauge to re-lay that section of track. 17 7/8 was not good enough.
I have not used the Ribbonrail products, but I have used the Peco Tracksetta products from England. They are outstanding, and have the advantage of slot cutouts in the middle that allow you to drive your pins into the ties directly below. Then, lift off the tool. Recommended. Ex. Walthers #552-OOT42. Can also be ordered in England.
https://www.walthers.com/tracksetta-track-laying-template-42-quot-106-7cm-radius-curve
http://www.hattons.co.uk/53255/Peco_Products_OOT42_1067mm_42in_Radius_Tracksetta/StockDetail.aspx
I think everything has been said about the Ribbon Rail track gauges. Truly a valuable modeling tool. I have used them for years with flex track and when doing hand layed track. They are well worth the small price.
Roger Huber
Deer Creek Locomotive Works
[Y] good stuff
Ooops! 'Missed the start date on this thread,but I still think the product is worth a mention… I recently tried these:
http://www.handlaidtrack.com/sweepsticks
and found them very easy to use. The pieces interlock,and you can easily mix radius’ to transition from gradual to more extreme curves.
I’m not knocking RibbonRail at all,just mentioning an alternative.
Mike
I used a homemade trammel and the pencil-on-plywood method to lay out curves on my plywood roadbed (for cutting them out) but you can also include lines for track centres or tie edges if you need such aids.
If you want low-cost guides for laying flextrack, you can make your own using corrugated cardboard from an appliance outlet, where it’s usually free for the asking. The large sheets can yield forms for some pretty wide (and long) curves, and a homemade trammel, a pencil, and a utility knife are the only tools needed. You can make outside-the-curve versions, inside-the-curve, or even ones for use between the rails.If you’re the type who calculates easements, they could be drawn on the cardboard, too, and included on the ends of each template.
As I mentioned back in my March 2015 reply, the Ribbonrail Track Alignment Gauges cannot be beat. They are metal, fit securely between the rails, and hold true while working with the track.
Speaking of Ribbon (welded) Rail. This is the transport train for welded rail segments on the subway.
ROAR
I have used both. In my experience, Ribbon Rail works better with Micro Engineering Flex, while the Sweep Sticks work better with Atlas, PECO and other brands of flexible flex track.
Another advantage of Ribbon Rail, is that there are no interlocking connectors to break.
