The wheels on the train go round and round
Early cutoff of the steam also makes better use of the steam–after admission is cut off, the steam continues to expand, forcing the piston away from the a
In my opinion, the answer is yes in the sense you’re asking. The driver tires, as they wear, decrease the diameter appreciably, which increases the effective torque per stroke all else kept equal (schlimm, I pointedly avoided ceteris paribus here) while having a slight effect on diameter-speed-related concerns.
I would add a bit to what tree68 has said: notching up the gear is a bit like varying the spark advance AND fuel-injection modulation on an IC engine. Some of the more advanced poppet-valve gears also vary the timing in the ways systems like VANOS do, and it is possible (although usually done only with dumb relief valves) to alter the analogue of effective compression ratio somewhat. But the mechanical advantage is basically the same for a reciprocating locomotive as it is from piston to crankshaft in a motor, and it seldom if ever pays to play with that aspect of the design.
The history of early steam is replete with approaches that combined gearing with reciprocating engines; even the Fontaine locomotive approximates gears with friction wheels. The second Harrison locomotive used gearing to approximate the effect of large drivers without invoking problems of effective short stroke and very high wheel diameter, and had the state of materials and machine tooling been better at that time, some sort of change-speed gearbox might easily have been provided to allow good starting torque and good high-speed efficiency (of just the kind provided an IC engine by clutch/TC and multispeed transmission). Note the plethora of gear and chain ‘assistance’ in the locomotives in the original Seraing testing, and how (interestingly) some of the answers to near-zero rigid wheelbase in Europe involved not gears but fancy lateral and swivel arrangements with what
