thinking about live steam for myself
I have been wanting a garden railroad for myself for a long time now, and I have finally got the space outside for it. Call me crazy, but the first thing I want to do is scratch-build a live-steam locomotive, with the aid of some books, like Building Small Steam Locomotives and Making Simple Steam Engines . I have a lot of questions, and I hope anyone can help.
  1. With a coal-fired live steamer, would it be O.K. to use crushed Bar-B-Que grill Broquettes for the whole session?
  2. I read the articles on the Garden Railway website about live steam, and something mentioned once or twice was the use of some sort of oil in the water. Is this oil needed? If so, can I use regular oil from the hardware store, or should I get it from a live-steam specialty company?
  3. I plan on using RC controls, but I’m not real sure, as I may operate it manually for a while. How do you protect the cab area from heat and/or water?
  4. Yes, when my budget allows for it, I would like to try to get a kit or ready-made live steam locomotive. Can anyone reccomend any manufacturers?
  5. If the locomotive derails, should I immediately extenguish the fire and wait for it to cool off, or should I have some sort of spacialty tool to re-rail it?
  6. If there’s anything I missed, Can you point it out and tell me what you know as to help aid me with my attempts?
Thank you for your time. In case you are wondering, other than what I have seen since Febuary 2008 (when I got my first Garden Railways magazine) I’m virtually clueless, so any help that can be offered is greatly appretiated. Also, the main reason as to why I want to jump in over my head by starting off with a scratch-built live steamer is because I have a budget of next-to-nothing ($60.00/mo
You might want to get a Mamod locomotive just to get your feet wet before making any attempt at making your own engine. Also you could fine an kitbashed loco somewhere and start there. Hope this helps. - Peter
I am in live steam in a somewhat larger scale, but I’ll chime in on a couple of points.
  1. Yes, you can fire on charcoal, but… there is a reason most people don’t. Charcoal is consumed very quickly compared to coal. I know in larger live steamers it can be a challenge to keep enough in the firebox, let alone the sparks that tend to set stuff on fire. Coal has more BTU’s per pound, so you don’t have to keep feeding the fire constantly. This may be nearly impossible on a G scale loco. However, it would be a cheap experiment since charcoal is pretty inexpensive.
  2. Steam Cylinder Oil is a necessity to keep the engine from wearing out prematurely. Regular oil doesn’t work nearly as well as steam oil for a couple of reasons. First, the steam oil is water soluble, whereas regular oil mixes with steam about as well as… well, you know… oil and water. Second, steam oil is meant to work with the elevated temps of steam. Search the live steam sites such as www.discoverlivesteam.com and you will find a supplier that will sell smaller quanities that will last you a long time.
I would second the opinion of buying a Mamod or Accucraft Ruby to get your feet wet before scratchbuilding. However, you might find a secondhand Mamod or Wilesco stationary engine cheap that you could use as a starting point for a backwoods chain or gear drive logging loco. I would also recommend finding someone locally that runs steam - no matter what scale or type - just to mentor you. You can pick up a lot just by spending a day around a steamer asking questions.
Best of luck, keep us informed on your progress!
  • James
What you have to do and do it now -are some calculations… These relate to the boiler and the cylinders. The first starting point is to decide what is the maximum operating pressure of your boiler and then to do the design spec for a boiler that will withstand TWICE that. This is because a hydraulic test will have to be done on the boiler before steaming at twice the operating pressure. You then have to work out how much steam your boiler has to produce. This is found by multiplying the volume of the cylinder by the number of power strokes per minute. Have a look here. http://www.cabbagepatchrailway.co.uk/heilmann.html If you have problems I can help you with the maths. A well designed steam locomotive is a joy - a poorly designed and built one is a bomb waiting to explode… regards ralph
Thanks for the help. I would like to explain myself for the reasoning of why I think the information may (or may not) be followed.
Well, I chose charcoal for the simple reason that it’s cheep, and avalable anywhere Bar-B-Q supplies are sold. As mentioned before, I only have an income of about $60.00/month, so I always try to stay on the “Cheep” side of the tracks.
O.K. I will look into ordering some through my local hobby shop (Normally, they don’t charge for shipping)
Again, I must report that money is a big issue. The only companies I have found are overseas (
I certainly understand being on a budget! One option you might consider, especially for a first engine, would be a propane or butane fired boiler. Those fuels are available virtually everywhere in small quanities and require less attention than a solid fuel like charcoal or coal when running. They are also cleaner and don’t emit sparks like solid fuels. The little stationary steamers typically use special solid fuel tablets that can be difficult to find at times.
On www.discoverlivesteam.com, they have live steam clubs listings by state. Take a look and see if you can find one near you. Visit and ask questions, most live steamers are glad to share information.
Anyway, a train hobby is like eating an elephant, just do it a bite at a time. Try to make progress every week on the train or track - no matter how little that progress may be - and you will eventually achieve your goal. Persistence is important! If you run out of hobby money for the month, scavenge materials, or do site preparation for the track - once you own the shovel, digging is free!
Again, best of luck!
  • James
One more thing, you might check out online auctions for Mamod or Wilesco toy steam engines. There are a few of the Mamod steam traction engines on Evil-Bay right now. One has been sitting a while and isn’t as pretty as the others - it has a starting bid of $45 with no takers. I realize that would blow the better part of the months budget, but it uses a steel spring as a belt that could be run over pulleys on the axles of a small “logging” locomotive. Believe it or not, here is a picture of a shay that had the boiler and engine replaced with a steam traction engine boiler and engine: http://www.gearedsteam.com/other/images/ford_mill_co_willam.jpg
Beauty is in the eye of the beholder, but you could use the Mamod engine as the starting point for a somewhat freelanced four wheel version. Use your imagination!
  • James
I’m looking at the listings for both Florida and Georgia right now, and, if that club is listed, they must have had a long way to travel. In North Florida (where I live) it’s basically a hobby desart, as the only places for any hobby is two or three hobby shops, and they mainly carry HO, O, and N scales (their is one or two G scale cars on a shelf gathering dust, though).
Good news. I have sort of got a rough plan for my railway sketched out. I’m just going to have to scratch build a lot of track though. All the more reason to learn to weld.
With the propane or butane, I’m not too sure. the only tanks for a hundred miles are those 5-U.S. gal. tanks for Bar-B-Q grills, way too big (trust me, I’ve searched everywhere.)
Also, with the E-bay lead, there’s no way it’ll happen. Don’t take me as ungreatful, I got too many “like new” things from there that just didn’t work, and now reside in my scrap box (except for an O scale caboose, which was marked as an HO scale item. I sold that a long time ago)
One last question that I want answered before I think about live steam any further, If the locomotive de-rails, should I immidiately extenguish the fire and let the locomotive cool down, or should I be really careful and use a special tool to re-rail it with the fire still going?
I completely understand about buying secondhand stuff online. I also prefer to inspect items in person before I buy!
When I mentioned propane, I had in mind the 14 or 16 oz containers that they sell for small torches at hardware stores or Wal-Mart. The skinnier 14 oz size might fit in a boxcar. Just an option to consider, use whatever fuel works best for you.
As far as rerailing a hot locomotive, get a good pair of leather gloves - such as welding gloves, or even work gloves - and pick the loco up by the front and rear of the frame or cab to set it on the track. The frame and cab will be cooler than the boiler, and the gloves will help protect against an accidental burn. If you can make a tool to help, that is fine too. I bet you can rerail it faster than you could dump the fire if you are using charcoal for fuel. No need to put a fire out and cool the engine off just for a minor derail. If it rolls over, that might be a different story, but you would want to upright it quickly anyway. The only time I would worry about dumping a fire and letting it cool down is if it makes a hard detour off the track and winds up nosedown with no water showing in the glass. Most derailments shouldn’t be a problem for you.
Hope this helps!
  • James
Thanks for the info on derailments. Even though I don’t plan on having any place for it to happen, I’m sure my locomotive will find a way to take a swan dive, and have no water in the sight glass. I’ll invest in a good pair of leather gloves.
I’ll try to go to Wal-Mart soon to find the propane bottles. Funnything,though, is that the local Wal-Mart is suppose to be the seccond-largest in North America, but their stock of X-supplies that would be found at another Wal-Mart is no where to be found. There’s still a chance for the bottles, though.
Another dumb question: I plan to have a river with a bridge to have the train (for photographic reasons) cross the river by an old mill. If the locomotive derails, would the boioler explode, or just put off a lot of steam? I saw a video a few days ago, where a steam locomotive went over a bridge and the boioler exploded (like what happens when you throw water on to a hot skillet.)
Thanks for being patent with me and my (possibly endless) questions.
It isn’t very likely that a live steam loco taking a dip in the water would explode. It’s not the best thing for a boiler, but shouldn’t lead to a catastrophic failure. If it is a concern, you might think about a through truss type bridge where the train will be contained in case of a derailment. Even a trestle could have walkways or low sides along with the gaurdrails to help contain the train. Most boiler explosions are a result of a crown sheet failure due to a low water condition. Was the video you saw from a movie? Movies are notorious for having explosions that don’t make sense, for instance, a car goes over a cliff and explodes before it hits the ground… that kind of thing. It would, however, make a lot of steam. The only real life example I can think of is a story of a track set up around a swimming pool (it was a nice level place) and the steamer derailed and went in the pool. No damage was done to the steamer. This story was from Model Railroader many years ago, it was one of the “Rocket” live steamers that used to be available. I can’t remember the issue, although I do think it was in the “Bull Session” column.
Keep asking questions, it’s one of the best ways to learn!
  • James
I’m glad about that. I don’t remember the T.V. show, but I don’t think the locomotive explosion was of “Hollywood Trickery” with explosives. I figured, if it could happen in real life, with a full size locomotive, then what’s there saying a scaled-down version couldn’t happen.
While on the topic of boioler explosions, if one should unlikely happen, what would happen(besides the obvious loss of a locomotive)? Also, if a locomotive does explode, will any shrapnel (eather kicked-up or from the loco itself) be cause for alarm? In simpler terms, if it does explode, can anything become a deadly, unguided missle?
Well, I want to be careful with this subject. Model live steam locomotives, operated with proper care, are very safe with an extremely good safety record and very, very slim chance of explosion, especially a single fire tube boiler like many G scale locos use. Having said that, an explosion of any pressure vessel is dangerous. Water expands about 1600 times when it flashes into steam. A quart of water in a small ruptured boiler would expand to 400 gallons of steam instantly. Depending on how it fails, the boiler will probably travel some distance, just like the real ones, and yes, loose parts will fly. However, this shouldn’t make us have an unrealistic fear of steam locomotives. Rather, it is a reason to have a healthy respect for their care and operation. It should spur us on to learn as much about sound boiler design and construction techniques as possible. We should strive to operate as carefully and attentively as possible. Our hobby has a great safety record and those of us who participate in it have an obligation to help keep it that way.
Now, I know that this isn’t a cheap book, and the subject matter is a little more in depth than most G scale live steamers will need, but I would recommend “So You Want to Build a Live Steam Locomotive” by Joseph Foster Nelson. It covers all aspects of live steam locomotive construction, including boilers. It is a great primer and resource for anyone who would like to build a live steamer.
Keep researching, reading and asking questions! Learn all you can, you will be a fine “Live Steamer.”
  • James
I would personally suggest you find and read very closely the book “Model Boilers and Boilermaking” by KN Harris. I would also recommend that you find and read “Building Small Steam Locomotives” and “Practical Garden Railways” by the late Peter Jones. regards ralph
That has put my mind at ease. Thanks James
As for that book, “So, you want to build a live steam locomotive”, that is accually the book I was planning (and still planning) to get. I also plan to get another book “Making Simple Model Steam engines” too. Unfortunately, on Amazon.com, the total will be about $60.00, so it’ll blow my budget.
I have been able to get some extra money here and there by working for my mom, and selling some of the eggs my chickens lay. I don’t think that’ll get me huge quantities of anything that’ll buy (or build) the farm, but I can at least get some detail parts for my smaller indoor HO scale railroad (I like both scales equally) and I can get started on a detailing project.
Or, I could get the parts that I need for those engines I mewntioned awhile back, so I can try my idea for “Live Diesel” locomotives. Mabe I’ll place the 2-stroke engines into some ALCOs[:D]
I’ll try to keep you updated on how it’s progressing.
I’ll look forward to your updates! I’m going to have to buy the books that Ralph recommended, too. Perhaps you can set aside part of your budget for books every month, saving up until you can order one book at a time. The information is worth many, many more times than the price of the books!
Best of luck,
James
Edit - Hey Ralph, thanks for the book suggestions. I have “Model Boilers and Boilermaking” and “Building Small Steam Locomotives” on order… can’t wait to get them!
I know about having refrence books on hand. I have a few hobbies that require them too (indoor model railroading, acale modelbuilding, etc.), and I try to get books (eather how-to or refrence) as often as I can. There’s one in particular thet I will remember for a long time, as the book has an interesting story too. Here it goes:
About 2 years ago, my family rented a cabin in Dillard, Georgia ( a very small town, garunteed that a GPS will say you are getting close to Nowhere) and stayed for the week. I remember that there was a small railway museum that looked to be in an old depot, across old Highway 441 from a private school. Being the train nut I am, it sparked my curiosity, and my bugging ability. We tried to go the next day (Tuesday) and we found out that the museum was only open on the weekend.
My dad promised me that we would go there just before we left. During that week, we traveled here-and-there, to the Tallulah Gorge state park, to Tallulah lake, to the old overlook on old 441. On that day, we went through this small neighborhood further down 441, and I found a railfan’s delight: An old Tell-tale (in original condition, rust and scaps of rope and all) and about 100 feet further down, an old wood sided caboose turned museum! My family can tell you, the van bottomed out while going 0 MPH on a flat road when I saw those two gems. I never knew that a railroad was ever in the regon. We stopped in at the caboose-museum (Luckily, it was open) and I started reading the papers behind glass, which told the story of a railroad I had never heard of, the Tallulah Falls RR, which was a short line that ran in the Tri-state area where Tennissee, North Carolina, and Georgia came together. I was (and still am) immidiately hooked.
When we went into town, we stopped for dinner at the Dillard House (a really nice hotel that just screams Southern Hospitality) and went into the gift shop. I was thrilled to find a book on the "new fou
Well since you are “strapped for cash” as we say in the Uk -then take heart! Quite a few books on steam locomotive making and suchlike are now available to read and down load from sites on the internet. My personal budget is £10 per week for my my railway, out of which I seem to be able to build and construct anything that I choose to. regards ralph
I’m back with another (what I see as somewhat doumb) question:
I know that steam-oil is needed for the locomotive, but I have been wondering, Can it be possible to lubricate the cylinders to the locomotives before firing-up the locomotive?
I doubt this would work, but it doesn’t hurt to ask.
P.S. I’m also going to be setting up another thred for “live diesel” locomotives, to get input as to weather it could be done or not. Don’t worry, I still plan to build some live steam locomotives. It’s just that the gas engines I have are calling to do something else other than sit on the garage floor.
The answer to that is “not really” as the lubrication is internal to the cylinders. This is normally done via a “displacement lubricator”. A very simple thing that it basically a screw topped tank in which the steam to the cylinders passes over before travelling to the cylinders. Some of the steam condenses and this forms water which lifts the oil into the stream of steam and is then blown into the cylinders. At the end of a run the tank is emptied via a syringe and the oil topped up. Here in the UK they stock two types of Steam oil -“Light” and “Heavy” the Light is for external lubrication while the Heavy is used in the Displacement lubricator. I hope this helps. As a first locomotive to build could I recommend that you investigate the “De Winton” type of loco as these are simple to build and understand how to get to work. regards ralph
