I have an O Scale Thomas the Tank Engine 6-31956 set which Thomas engine does not change from forward to neutral to reverse when the power is interrupted.
The switch to change directions is ON.
I discovered if I add a lighted caboose car then the directional switch does work when I turned power off with the red transformer speed control arm.
When I take off lighted caboose it does not work anymore.
Anyone know what is going on and how to correct.
Had similar but disimilar issue with a railsounds locomotive that would put out erratic sound if the light bulb was burned out.
Confused
Cheers
Steve
