Those 3 little bolts!
what do the 3 bolts do on the front of the wheel on cars and locos?
At the outside ends of each axel?
http://www.rrpicturearchives.net/showPicture.aspx?id=462244
If those are the 3 you are talking about simple they keep the roller bearing from COMING OFF. The bearing bolt is torqued on to IIRC 475ftlbs to preload it and then the retainers are bent over to lock it on then you install the wheelset.
