While my Tonopah and Tidewater depicts the arid desert of Nevada, actually operating it in a 115 degree heat is probably a bit too realistic. It has moved out of a spare bedroom with house AC into a 11x20 3rd car garage attached to my house in the Nevada desert. This garage is an integral part of my house and the attic is above the garage. There is access to the attic in the roof of the garage. I’ve insulated the garage door and it heats up pretty fast with a small electric heater.
The big question is cooling it in the summer. My first two thoughts are to have a AC company run a duct from the house AC into the garage thru the attic. It would make the garage part of the house cooling system. The alternative would be to install a small AC system like the Mitsubishi systems sold at Home Depot with the compressor outside and a single cooling unit attached to the inside wall. Does anyone have any experience with doing this? What are the problems I am likely to encounter? Any other ways to cool this down in the summer? Thoughts and opinions? Thanks.
