Do I really need tin snippers for .032 thick brass or can I just use a regular paper cutter? Thank You - Peter
Tinsnips for thin metal, paper cutter for paper…
Dave
For brass that thick, I’d use snips. A paper cutter is not quite what I’d call a proper metal shear. It might work well enough for shim stock (.010" or less), but you may do more harm than good to both the metal and the cutter if you made a habit of cutting thicker stuff on one. (I’d strongly advise against using the one in the mailroom at the office.)
Later,
K
Paper cutters that are made of real steel and real wood (weighing in at around 30~35 pounds) can handle thin soft metals such as soda cans and very thin copper roof flashing. Brass is entirely too hard for most paper cutters. General rule of thumb for me is if I can fold and crease it using thumb and one finger then I use paper cutter. If I cannot put a good fold crease then I use tin ships. The paper cutter I have in the garage is one my dad purchased back in the mid 50’s, it has a real hardwood deck and heavy gauge steel blade.
