Here’s my question, I have my mainline running from my yard around a appox 35 in radius, into a 2% grade, for some reason, when I run my double stacks on that curve and grade, they tip over, my track is postioned fine, ( so I thought) what can be the problem??? that has me bugged!!!
Do they tip toward the inside of the curve? Is the grade just before the curve or at the end? Where does the tipping take place in relation to the place where the curve and grade meet?
I agree with all the preceeding posts, and may I add…
Make sure your curve has a proper transition, AND the incline has a proper transition as well. Sudden changes in trackage horizontally and/or vertically can mess up your train.
One other possibility is your train is too long/heavy for the weight and/or center of gravity of the cars.
Gidday, if your other rolling stock is negotiating that curve O.K, from what I’ve seen, (not my modelling era), of those cars, they appear to be too light and too high.
One other thought though, is there one particular car starting the fall each time?
If you found more room and now have much broader curves, that’s great. But the fact that the cars are derailing suggests that it’s probably not actually 35" radius. Especially in N scale.
A 35" radius curve would be more than 6 feet across (diameter) with the benchwork. Is that what you have?
If the cars are “stringlining”, that is, derailing across the center of the curve, this is often the result of a steeply graded curve that is too tight, too steep, or has too abrupt of a change from level to grade, as others have noted. And the combination of those problems is especially bad.
Loaded double-stack models could be too light for their length, although many are heavy enough. The center of gravity is high, which exacerbates the tendency for stringlining.
By the way, the NMRA standard for car weight in N scale is .5 ounce plus .15 ounce for each inch of overall length of the car. If you have a particularly demanding combination of grades and curves, weighting beyond the NMRA standard may help.
Note also that poorly-rolling cars can exacerbate the tendency to stringline, as it’s related to friction. So if the car-weighting is overdone, it could make matters worse if it causes the cars to roll poorly…
