I believe Lowe’s or Home Depot have small angle iron in both aluminum and steal that is in all different sizes IE: .75 X .75 flange up to 2 inch flanges. they might have 90 degree clamps
Perhaps a drafting triangle. I have had mine since highschool, but they may be available at a school store or an office supply store.
Perhaps a low priced square from Sears, Home Depot or the like. Probably 10 bucks. (total guess)
Or make your own using classic dimensions of a right triangle: 3,4 and 5 inch sides (or any dimension in that ratio. (3 squared + 4 squared = 5 squared)
Anything laying around the house that is square? Put it on a straight edge and strike a vertical. Then flip it, like turning the page of a book and see if a new vertical is parallel to the first line. (Test anything you purchase this way also.)
WEll, a block of wood that is sqare cut with a 90* edge could work.
But you can find 90* angle angle irons or t-squares in smaller sizes for cheap money.
You might even strike one at a dollar store in the tool section.
GO get yourself a “speed square” triangle which costs only a few dollars, is about 8" along a side and is desinged for speed in marking and cuting 45* angles of wood.
Exactly what I needed, guys; thanks. Based on my trials, all will work beautifully. The speed square (which I have but overlooked) is heavy and long enough to support the spacer and assure it’s square. Putting a block of wood or the drafting triangle next to it will assure the edges align, too. Sweet!
An inexpensive drafting triangle (Michaels or Hobby Lobby) or a square (Lowes or Home Depot) will work just fine. The problem with cutting something out at a 90 degree angle is that if you are off a degree or two - very, very easy to accomplish - those will multiply the error as you go around the turntable.
