Problem: Can’t get Lionel tmcc Rock Island 1274 GP7 Diesel link to work with a MTH DCS.
What I have: MTH DCS with remote. TMCC base. 9pin cable (proper cable). Z750 Transformer. Ground wire.
What’s going on: When I switch the engine to “prog” and turn the transformer on to attempt to program it, the engine moves. It won’t stay in neutral to allow the system to program.
I’ve checked and re-checked the wires and cables. (I know the 9 pin has a certain way it will is supposed to go).
Originally I tried to program it on my layout with accessories and switches. I thought the accessories or the switches might have something to do with it not working so I moved it to a dedicated track and it still won’t work.
The TMCC Command Base must be connected(“U” to outside/running rails), and powered with it’s dedicated/proprietary Lionel wall-wart AC adapter plugged into a grounded AC outlet before powering up the locomotive.
Based on your observations the Command Base signal is not being passed thru the MTH TIU to the track, consequently your engine is starting in conventional mode.
I agree. Is there any way it is a software issue? It’s 2.1 . Just a thought.
It is plugged into a grounded outlet. It is working because there is a green light. The “U” wire is running to the ground (as per the directions in the DCS manual).
I’m not sure what a Proprietary Lionel Wal-Mart adapter is. ?
You must use the original, 3 pronged grounded wall-wart to power the TMCC base. A substitute won’t work. And it must be itself plugged into a grounded outlet. If any kind of adapter is used between the power supply and the wall(including terminal strips, surge strips, etc.), it may not be connected to ground.
An alternative is to run a wire from pin 5 of the Command Base rs-232 port to the ground screw of a nearby grounded metal duplex outlet or household electrical ground until you get the right adapter.
