Trying to figure out if I am doing something wrong, or if this is standard operating procedure.
I have a new ZW powering TMCC with DCS installed.
The ZW is connected as follows:
A to Track 1, through a Ckt Bkr, then to DCS Var 1, then to Track 1 (primary track power source)
B is connected to DCS fixed In 1 (providing fixed input volt to DCS)
C is connected to Terminal Block via Ckt Bkr, (providing voltage for building lights)
D to Track 2, through a Ckt Bkr, then to DCS Var 2, then to Track 2 (primary track power source)
Operation is fine in either TMCC mode or DCS mode, with either TMCC engines or DCS engines and controllers.
Upon powering up, I must select TR 1 (A), with the TMCC controller, and increase the voltage. At start up the initial voltage is only about 8v, meerly touching the “throttle”, and the voltage jumps up to 17v. And of course everything is fine. But I need to do this everytime power is turned on, same thing for D, or “TR 4” on the TMCC controller. I assume this is because these are the variable outputs on the ZW.
Both the TMCC and DCS remotes will then work fine with the appropriate engines. DCS anything, and TMCC everything but DCS engines.
Now to run convential this is what I have to do upon turning on the power…
Have the DCS controller in one hand with “Var Track 1” selected, select TR 1, on the TMCC and move the throttle, immediately the voltage jumps up. The convential engine begins to move at full speed, until I move the throtle knob on the DCS hand controller. Then I have full control.
So the basic question is this “normal” ?
I can’t seem to have the potential 17v at start up without adjusting it with TMCC, and then the minimum voltage on the DCS is set at 5v (lowest setting), and in the mean time the engi
