I am trying to build a lash up with my CP SD-90 and my WM Consolidation. I have tried Train 1 and Train 2 settings, but neither worked. I was wondering why it didn’t work. I got the instructions from the TMCC manual. Both locomotives are TMCC. I am upset by the problem.
Have you assigned each engine a unique number? If both engines are set up with the same engine number it won’t work.
If you are using TR1 and TR2 for tracks then you can’t use them for Trains. I take the number of tracks/lines I have (in my case 4) and assign my Tracks to 1 through 4, then my Trains will start at TR5 and work their way up from there.
