TMCC PowerMaster Not Powering Down
Hello everyone!
This is my first post on this new account! Anyways I’m having an issue with running my conventional trains with my TMCC set up. I was able to run them before with the PowerMaster and PowerHouse set up but recently something has went wrong. I can’t power down the brick enough to cycle the E-unit on the trains. It’s like the voltage wont go below 8v or so. I tried resetting it and that didnt work, I made sure it was set to conventional mode and still no change. It seems like an electrical component on the inside has gone bad or something. With some research I found a thread from a few years ago that just said to do the stuff I mentioned above. I tested the system with a TMCC engine and when I try to power it down it still hast power going to it and I am unable to power down the track. Any help would be appreciated, I spent a decent amount of money on the set up and would like to use it lol.
-Ian
tl;dr Tmcc powermaster wont power down enough to cycle conventional trains even after resetting.
Read the manual & reset / set the “stall” voltage of your PM-1 to 0 volts using the buttons under the bottom sliding cover of the CAB-1.
