TMCC to fastrack?
I recently bought my first TMCC control system. its the basic, regular version. ive seen people use it with fastrack, but how is it hooked up? you since the wires plug into the bottom of the track you cant connect 2 wires to the same hook up. How do I set it up with fastrack?
There should be two wires from your transformer going to your fastrack. Connect the TMCC to the same post on your transformer as the one which goes to the outside rail. This is the same as connecting it directly to the track. (You can put two wires on the same binding post.) You could also scrape some insulation off of the wire that goes to the outside rail and splice the wire from the TMCC to that one.
Carl
FYI…you can download just about every instruction book printed by Lionel on their website, including their TMCC instructions.
Already did. it dosent say for to connect to fastrack.
