To be sure that all modern rolling stock [husky stacks and etc.] can make it through a tunnel, what is your recommendation on portal heigth and width [single track and double track]?
I would like to know that myself.The layout I’m still planning and revising over and over keeps getting changed every time I see a new scale car come out.I’m going to put a branch line into another room(more for storage tracks).I was guessing to make the boar at least one inch above the tallest piece of equipment on rail that I have.That’s just a ballpark figure .
Chief & Mackb4, If I could do what you are planning, I’d use the dimensions that the real railroads use-- Height 23 ft. and width 14-15 ft.(scaled down to O dimensions of course!) . This should clear most modern equipment, as I don’t know of any rair car that won’t fit those dimensions(except maybe a Schnabel transporter car).
HTH
Chief, if you have a husky stack laying around, I would mark how high the car is, and add the height of the realtrax roadbed that you are using. So, the height of the realtrax is about an inch, and add that to the height of the husky stack car, and I think that would work. That is what I did with a tunnel I built for my layout and it worked well.
For width, I would take your widest engine, and if it is double, multiply it by 2 and add 2 inches, maybe 3 if its on a curve. On a straight, I would put an inch clearance on both sides, maybe 2 because of the spacing between the tracks.
Chief…If it’s at all possible make generous holes in your walls that can later be scaled down with portals. I’d want portal dimensions at least 6’’ from railtop to keystone and 4" width for a single straight track. Of course the opening height will vary with the type of track and roadbed used. The tallest piece of equipment I have is a scale GG1 and with raised pantograph it will barely clear the 6" portal described above as long as the opening is rectangular. I can’t think of a taller piece of equipment unless it’s another electric.
Chief… One question I will ask is…Is this portal on a straight track or a curved track ??.. I went with 7 inches from the top of the track. It’s a little high but I can scale it down easily. I have a track of 42 " radius and a track of 31 " radius taking a curve thru a portal. I was surprised how wide I had to go to allow all the various cars to clear each other and the portal sides.
Chuck
The dimensions are 4" wide, and 7" tall. The only thing you need to keep in mind is, if this is on a curve, you may need it slightly wider to accomodate overhang from longer cars. That’s single track of course, double the width for double track.
Frank, I’m surprised you don’t remember the helix.[;)]
I used a triple portal on my layout for my 2 track main curve. I have 7" in hieght and 10" in width. My MTH Big Boy still hit the side but barley. I have a minimum of 2 1/4" from the edge of a curve to the outside rail I think 2 1/2" may be better if you have the clearance. That amout doesn’t look out of proportion. I have a 1 1/2" inside minimum to deal with the big diesels and the Cascade engine or the Auto Carrier. I have 072" and 083" curves.
On the Hieght, I have 6 1/2" above the top of the rail and wish I had more The Schanble and the Auto cars from MTH are the tallest I have. But I’m now adding catenary and wish I had another inch under my bridges and tunnels. I similar problem the east coast railroads have. Who knows what will be made next? Wide Loads?
On thing that has gotten me is the Lionel Hell gate bridge 2 track. I have stuff that I can’t see any space but they don’t hit. It would be a good straight track templete. I use Gargraves.
Dear Blueberry,
It is obvious that my services are going to be required in Roseyville in the near future. Would you like to join me on the road trip to shore up Chief’s house after he makes this hole in the wall, cuts several load bearing suport members and the house starts to become instable. Please bring your own hammer and crow bar. [(-D][(-D][(-D][(-D]
(I can’t believe Pam is letting him do this or does she know???)[:0][:0][:0]
BOY, this is serious & I hope you guys can get there in time. Better start packing,
maybe I can send some tools down in time !
Right now, time is of the escence ! [:D][:D]
Also, better get a hold of DR. John , we have to try & save the marriage too ! [:D]
Hope this helps, John !
If my wife knew I was cutting holes in the wall for a tunnel, it would have to be large enough for me to bring my mattress cause thats where id be sleeping!!
lot of luck!! with the project and the wife
John, it sorta reminds me of hurricane relief. In this case the hurricane is Pam. the Chief is FEMA and we are the Coast Guard. Maybe Dr. John should go in first so Blueberry and I don’t get shot.
Believe it or not, the trains running into the walkin attic was HER idea. [:0][:p][:)] Toots, did the YOUNG lady of yur house give yuo permission to go through walls? [?]
Yep, it was her idea also. The only question she asked was …Why they
came back out. I have to think about this. Did " your young lady " realize she had to clean up all her junk first???
