I’ve been following Timboy’s progress and new design with great interest. Got to thinking, again (not always a good thing [;)]) If I were to…and I am…going to plan my -last- next layout, would I consider a “no switch” project. Instead of the sidings, that I now have, which lead into the trackside accessories like the milk platform and dump sites, I would dedicate a single track that would accommodate those features. One advantage, that comes to mind, would be the elimination of possible derailments and rough rides over a switch.
I’d be interested in your views about switches. As always, many thanks.
Switches can be a problem, alright. But, depending on what you want, you are going to need some. I have my accessories on a line as you describe, but wish I had more room to install sidings & uncouplers to allow more freedom to build a consist.
I remember that being a lot of fun as a kid, but didn’t get that designed into my present layout very well. Think I am going to add on a 2’ or so by 8’ for sidings. More switches!!!
If you are planing a retro 1950’s layout with the emphasis on running trains then you’ll probably be using less switches, more loops & less landscaping & “layouting.” (Remember 1950’s switches were expensive then, and layout space was usually temporary & limited). OTOH if your goal is a cover/coverage in CTT then a poll/opinion of others here won’t matter much. [;)]
In the design phase of my layout after having built five previous ones, I decided not to eliminate them but to see how few I could get away with… Like anything, if the sky is the limit, it’s easy to design a layout. I built a layout that perhaps defies current trends, as it is a high rail tinplate setup. However, I wanted to challenge myself which it sounds like something you are considering. I hindsight I could have eliminated one of the five switches and so what I arrived at was essentially three loops that each had a sort of s curve in them and a very elongated crossover ( more like a siding) between them, The outer loop crosses the inner one by way of a 90 degree crossover to a two track yard. The inner loop has a industrial spur with two industries.Five switches. The third loop is an elevated line for rapid transit. I don’t switch the industries so your idea would have suited me, and that would take out three…I go between runs of pre\post war Marx and the current lot of MTH, et al. I have tin accessories \ buildings mixed with modern ones in a hi-rail setting by way of separating them into “neighborhoods” ( I couldn’t resist that nearly two foot long Marx freight house ) …on one end I have antique block signals and the other modern ones…the contrast is enjoyed by visitors to see the trains pass through a modern day landscape into the past of toy trains and return. So I say…go for it…experiment,try it out as a carpet central for a few weeks…to play with …thats how I made sure I liked what I configured…
One idea I 'toyed" with (which I should have done, is to make the connection or cross over, a elongated siding by making a left hand switch from the outer, have it cross the inner loop to connect with it after paralleling it by way of a right hand switch. at the center place an isolation section. This could have been the switching spur and eliminate one switch.It could be accessed by both loops. By the way,I cut dow
On my previous layout I learned to make a small yard and have it’s own lead long enough to drill the entire industry area on one side of the layout. That kept the outer loop clear for running trains at track speed using the largest available switches in that track.
In O Scale switches are fun for me, but I have to be very careful where I put them.
The Club Railroad where I briefly ran trains had wide open mainlines with occasional switches to add problems and possible derailments. The switches are there to create yards, sidings and run around as well as even Lap sidings to saw trains past one another.
I try to limit the total number of switches on the railroad. I try to give all the track, switches the very best under foundation like… 3/4 inch oak plywood if necessary so that they will be strong and flat. I try to engineer track so that the biggest rigid frame steam engine will be settled approaching and departing a switch. I try to unload the grade before or after a switch in three dimensions so that the train will find the switch smooth.
Finally I cheat on the main a little. All or most of my switches have points that face away from the engine going in the most common direction for that line. I hate switches where the points are facing the engine with the possibility of “Picking” or derailments.
I would rather buy a top dollar switch and make it work flawless than fight with a kit switch that cost 3 dollars.
A long time ago my father built me a small pike and we used the absolute cheapest switch and rail. It worked well enough until I started thinking about operations, kaydee couplers and the like. Now that I build my own layout, I am absolutely anal about switches. They are done right as best as I can do them.
I dont accept substandard performance from switches.
But I will always remember my Pa for doing the very best in terms of wood, track, roadbed and the like despite the low budget for switches and track. I
I personally like a lot of switches. My carpet RR which I just picked up had 50 switches, 40 of them on the main line and 10 for sidings. I wire the switches so the train operates them and i just get to watch. This is toy trains, not model railroading. I have always enjoyed using the trains this way. I built a control panel that would allow me to run one train, 2 trains, or 3 trains depending on switch settings. Running a train moderately slow, it took 30+ minutes for the train to go over the entire layout. I used only 022 switches, and never had a problem with derailments. The train would run for 2 hours or more without a problem. One time, I even backed a 20 car train around a loop and onto a siding. One car did derail once, but it was a light car near the front of the train. I was using a 2333 for the engine. Backing 10 cars was always no sweat. I like complex layouts with lots and lots of switches. I remember the '50s also, when a 022 switch cost $11 and I was making $1 a day carrying papers. I am buying 022 switches complete for $7.50. And I can buy clean track for 50 cents. It was 35 cents in 1950 for new track. A new O31 section is now $2.89. Bruce Baker
I think it’s up to you based on what you enjoy. The yard for my layout are three wall mounted display shelves as well as two floor types. This is because I don’t stereotypically change consists like the real thing. My manifests are drawn up by the variety factor. My own preference is to compromise on the yard and in return I get more real estate which is oddly enough, a lot more prototypical (interesting) anyway…My earlier layouts looked more like like swirling amusement park rides than something my imagination could get a grip on as a facsimile of the real thing, When mixed with tinplate, it’s sort of a retro-futuristic depending if you are a kid or an oldster. The bottom line is fun without turning a hobby into an endless chore. I take forever to do things because it’s easy to burn out doing fifteen things at once.
Reaching way back, I recall my brother and I making dares to run the O gauge train through the switch (Or two or three) backwards with a full train without derailing.
Wealthy Children counted assets by how many switches they owned so that the friends could combine their own track and contribute a few switches too to make more elaborate railroads that otherwise may be too expensive.
If you can ram a train full speed forwards and backwards and not lose anything or disturb the conductor in the caboose… you have it all.
I hae to make a comment that down in Little Rock yards you are standing in a sea of track and wonder, how in hell does anyone is able to keep the right count of each track 24/7 day and night.
I’ll send some thoughts your way tomorrow as I’m just dead dog tired right now, however, you should add some switches at least on your sidings as they are GREAT fun and then you can build your consists with reason and destinations as objectives. Keep asking questions as there are certainly lots of idears and opinions[(-D]
To all: A lot of great ideas and “food for thought”. I’m still in the planning stage and am ‘negotiating’ for more space ( you think the Middle East peace conferences are tough…a “piece of cake” in comparison) [:)]
Appreciate your input. Keep the posts coming. I’ll keep reading. Many thanks.
Just my 2 cents, learning from experience, in everthing I have ever done, I use the KISS method. Keep It Simple Stupid. My new layout will be incorporating the least number of switches as possible, to avoid potential problems. I like to run my trains and we all know how embarassing it is to have someone over and a malfunction occurs when he brings his kids or grandchildren over to see if they are interested in the hobby. All that the kids remember is that it was broke.
The prolem for years was there really wasn’t a track system that had reliable switches. FasTrack has changed all that, and with the new Legacy switches building a command equiped railroad just got a whole lot easier. Had I known that Lionel was coming out with the Legacy switches I would have stuck with FasTrack instead of going Atlas. Therefore the next layout sure as tootin’ is going to have LOTS and LOTS of switches and will be converted back to FasTrack. [banghead] Well I may just build an outdoor layout with the Atlas track… bet The Q will blow a few thousand gaskets over that one. [:)]
lionroar88- *Tellyawhatimagonnado…*you are already pretty “dinged” up, so I wouldn’t tell the Q about any proposed track “upgrades”. Simply pick up some FasTrack (a section or two at a time), and quietly pull up that nasty old ATLAS track, and put it in a paper bag. Every couple months, we’ll pick out a “drop” zone at a predisclosed location along 70… And again, always glad to help.
Fife…if you call what Brent is “dinged up,” I’d pay money to see what “totally messed up” is. But you have a point…his layout is under construction and she wouldn’t notice the change. [;)]
