Here is what I was finally able to do (railroad related) today. The Glacier Gravel Building is built stock , I am just bashing the conveyors. Got to move to the other side now. You will not see the backside from the layout front , just the rear conveyor.
Here is what I got done today. The overpass will act as a partial viewblock to the portal at the window. The back side will be mostly trees to complete the block. The overpass will tie into a road that passes through the city area.
I built the over pass from scratch using styrene and the two iron bridge walls were from the Walthers Art Deco underpass ( I just had one laying around). The color is a mixture of Polly Scale aged concrete and concrete colors and used engine black and grimmy black for the weathering. The road surface is engine black and weathered with pastel chalks. The center lines were done with a colored pencil and a french curve and ruler.
very nice work you have done keep it up. your work is motivating me. i really like the depot in this video at the end with the 4 bnsf locomotives beside it. i just got an idea from you with the depot.
Merry Christmas to all!
Here is what I added this weekend to the ACTRR.
I have put in a 4 track yard on the front edge of the layout to handle all of my rolling stock that will not be on “made up” trains. Also added another Electro-magnetic un-coupler and the two caboose tracks double as the program tracks. I only had to make a small adjustment to the panel, by adding 1 DPDT switch to the program track and make the old program track switch a block switch.
This is a 2009 Hallmark ornament that I have re-worked. I removed all the snow and trimed off the snow base and put a new roof on. Then touched up the paint and added a few trim pieces anf here you go.
I have been working on the problem end of the layout. I think I have found a way to almost completely cover the loop into the garage wall window.
Here is the latest progress.
I enjoy very much to follow up on the progress of your layout. It is a pleasure to see, how N scale has improved over the years. Thank you for posting!
thanks for the update - you know I keep track on what you are doing [:)]
What really gets me, is the sheer size of your layout. I know, it is N scale, but even so, it covers an area I will never be able to have available for my “trains”. Right now I am happy to squeeze out an area of roughly 7`6" by 2" for my little “wonderland”.
