Together or separate?
Hello and Happy Holidays,
Been enjoying working on my basket case American Flyer 370 and 371 diesels. I think I want to lash them up for longs drags but what should I do? Keep their motors and reverse units running separate, or wire the motors together (like a dual motor locomotive) with a tether between the two and disable one reverse unit? They both run great and creep real nice either way so they’re good runners…of course I converted the 370 to couplers.
Any harm in keeping the motors electrically separate?
Thanks!
It is tough to run multiple Flyer power units together having to rely on the mechanical reverse units to keep them in sync. If you converted to electronic e-units you probably could pull it off without a tether between them. I did this on an American Models DC powered ABA ALCO set with two powered units when I converted them to run on AC. While it is not totally fool proof it has proved to be very satisfactory.
At least with the electronic e-units you could always run them independently when you wanted to.
I see what you’re saying but I thought I would just lock them out to go in one direction, one running forward and one running backward…but thanks for that idea.
What’s a good source for electronic reverse units for Flyer (or Lionel for that matter)?
I use the Dallee #400 for a dual-engine unit here, works great.
http://www.dallee.com/E_Units.htm
As you said you could just lock the reverse units and run them together. This is no different than running a single locomotive with dual motors. Most locomotives that have dual motors are not perfectly matched in speed any way. I have operated my GP7s the same way as you suggested with no problems.
