Im having sort of a dilemma here. Im looking for toggle switches with no off position. It would be an on-on-on circuit (constant power unless base power was turned off). I would like to use these switches for manual control of three light signals (to keep a tower operator busy). Any one know if anyone makes these or where I could get some? Thanks!!
Matt
Matt,
Have you could try this web site www.mouser.com they have all kinds of switchs and stuff. Hope this helps you out.
Philip
A three pole (position) rotary switch will accomplish what you want to do and it would be similar to what a tower operator would have on a CTC board…Vic
Would that be a 3 pole 4 position rotary switch? No luck finding an on-on-on-off toggle so the rotary seems like the only way to go. Just want to be sure Im getting the right ones. Thanks!
Matt
Hi Matt, Yep that will work…just use as many of the positions as you need.
