Topper Tape light or Heavy
Hi, The product used in U.S.A. known as topper tape I believe from API, as I have to import this can anyone tell me for HO the width and is heavy or light duty which is best after reading the MRM Great Layout Project 2 Flextrack I have decided to use this but it doesn’t mention the 2 duty types or width. Thanks Pete
What you need to be concerned with is the thickness and the width a minimum of 2" and the thickness .025 or 1/4". I picked some up in my local home center and it was not wide enough. Some suggest you can use two narrow rolls to make the correct size but that defeats one of the purposes of using it.
Thanks, the web site for API lists 2" and 3/16 thick for both Light and Heavy duty
