Tortoise and DCC
I am at a loss with the concept that to install a switch machine is so difficult when you can program an engine to run by itself without being an EE but you can’t install a turnout without a degree in wiring. The wiring is what takes the fun of this hobby away.
Could someone please show me a simple way to install and wire a tortoise to an insulated turnout with a DPDT and LED so I can move on with my layout. Pictures or a diagram would help.
I am so glad this new forum has emerged as I am electrically challanged.
Ok, I’ll start by posting a couple of links to diagrams that may help clear some confusion. Then lets see where we can go from there.
http://www.amhobby.com/products/tech/circuitron/wiring-leds.htm
The circuit shown at the link above puts the LED’s in series with the tortise, using the tortise as the limiting resistor. This means the LED’s would reduce the voltage to the motor slightly.
http://www.amhobby.com/products/tech/circuitron/signal-wiring.htm
Here is my take on the switching circuit with LED’s. Maybe someone else could check it and verify if it is correct. This circuit puts the LED’s in parallel with the motor so everything gets the same voltage, requiring the use of the resistor. I think the the value of the limiting resistor should be around 500-600 ohm’s rated @ 1/4 OR 1/2 watt. Somebody check my work please.
DPDT Switch with LED indicators for Tortise
Thanks for the response. It would help if someone had pictures of the wiring on their layouts. Thanks for the info
Can you be a little more specific ? Are you looking for wiring the Tortoise itself, bringing the wires back to a wiring distribution point or a control panel, using terminal strips ?
Ok. Maybe someone can help you out with pictures of their layout. I’m at the cookie cutter/riser stage on the new layout in this house so I can’t help with that yet. Sorry. [sigh]
Guys?
With the double pole, double throw it’s real simple
Flip your switch over. We’re going to label the points on the back like this
1 2
3 4
5 6
  1. Connect 3 and 4 to the first and last pin on your tortoise
  2. Connect 5 and 6 to the + and - leads on your DC power supply (12V+).
  3. Connect 5 to 2 with a short piece of wire
  4. Connect 1 to 6 with another short piece of wire
If the switch moves the points (turnout rails) in the opposite direction you expect it to, just reverse the wires to the tortoise. That’s it. You’re done!
Now the next question is, what brand turnout are you using? And do you want to use panel lights to indicate which direction the switch is in?
Thanks for the response,Jeff. I’m looking for the wiring from the tortoise to a control board with a DPDT.and a green and red led. Also How to wire an independant DC power source in parallel to multiple torti.
Thanks in advance to all for your help.
I’m using Atlas insulafrog turnouts and I do want the panel leds to indicate the turnout position.
Take a look at your LEDs. They have two legs. One positive, one negative (or sometimes called common/ground). The longer one is the positive lead. LEDs only light 1 way. So if you wire them up backwards, they won’t light.
So take the green led and hook the long leg up to terminal 3. Take the red LED and hook the long leg up to terminal 4 (backwards of the green). On the short leg you’ll need a resistor in series. If you are using a 12Volt supply, a 500 → 550 Ohm resistor should do the job nicely. So connect a 550 ohm resistor to the short leg of each led. Then hook the resister to the opposite leg from which the resistor is connected.
This graphic is easier to look at than an actual picture because tracing wires in a picture can be “difficult”. If you have any questions, please feel free to ask.
Note: If the red and green lights are reversed (For example: It’s green when thrown, red when straight) , just reverse the wiring to the LED legs.
If you are using a bi-color 3 prong/leg LED let me know, and I’ll draw another graphic.
Connect a wire from terminal 5 on the DPDT to the next terminal 5 on the DPDT. Connect a wire from terminal 6 on the DPDT to the next terminal 6 on the DPDT.
It’s that simple.
Since you are using insulated frogs, you don’t have to worry about routing power from the tortoise. You have the option of wiring the points to the rails for improved power contact. But it shouldn’t be necessary unless your locos are stalling over the turnout.
Sorry I can’t offer pictures but here is a diagram courtesy of Allan Gartner’s “Wiring For DCC” that describes the multi tortise wiring.
Double Crossover Circuit
I would be interested in the bi-color LED diagram. Also, when do you use 3 legs and when 2 legs (I see both types offered)
-Erik
Here’s a common 3 leg type
You hook the center in series with a 330Ohm/500 Ohm resistor then to the power supply +. If you ground terminal 3 then the red lights, if you ground terminal 1 the green lights, if you ground terminal 1 and 3, then both red and green will light producing a shade of amber to yellow. I believe if you connect leg 1 to point 3 on the DPDT and leg 3 to point 4 on the DPDT and leg 2 to the resistor-power supply, you’ll accomplish what you need. Important disclaimer: I haven’t tried this circuit. So it might not work as I think it will. It will not however damage your electronics with a short. So you should be safe
A two prong leg bi-color led will only allow either the red of the green to be lit, but not both. You need to connect the 330 Ohm (5 Volt source) or 500 Ohm (12 volt source) in series with just one of the legs and connect it to points 3 and 4 on the DPDT.
I generally just wire the LEDs in parallel (with the polarity flipped) and then wire them in series with pin 1 or 8 on the Tortoise. The 15ma coil limit of the Tortoise makes for good current limiting for the LEDs. I don’t need any resistors with this option.
Many thanks to all that responded to my post. This forum is a Godsend to anyone who shares this hobby. I have found for the past two years that people in this forum are most generous with sharing their knowledge. This is refreshing in a society that usually enamors a me first mentality. Again, thanks to all.
